best header 4 carbureted cars
Car: z28
Transmission: pro built 700r4 (road racing kit)
I’ve done plenty of searches, but all I can find is information on fuel-injected cars. My question would be this what would the best headers be for a carburetor car??? I have an 84 305 if that helps you guy out. Will hooker 2055 still work; on the jegs web site they say they only fit 86-90 camaros.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
yes the 2055's will work, and i highly recommend them. shorties into a 3'' y while retaining all your ground clearance. Good to go.
Brandon
Brandon
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Brandon
Brandon
Car: z28
Shifty If I understand you correctly the headers will bolt to my motor, and the y-pipe will bolt to the headers, but the y-pipe will not bolt right up to my cat? Basically what I would have to do is cut the old flang off the old y-pipe and weld it to the new one right? Hears another question is the y-pipe that comes with the 2055 a 3-inch pipe, it doesn’t say anything about it on the jegs web site as far as I can tell. Also is it worth it to get the coated headers? Oh one more thing were is the cheapest place to buy these headers?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The y-pipe is a 3-incher. The Catco 9118 cat is a perfect fit. Add a Hooker catback, which is also a 3-incher, and you're set to go. Coating will reduce underhood heat and protect the life of the headers. The cost may be prohibitive.
JamesC
JamesC
Car: '90 RS
Engine: 377 LSX
Originally posted by D's89IROCZ
Not to confuse here but ...
But aren;t the 2460's the exact same thing but without AIR and cheaper ?
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
You can get SLP's too without the AIR stuff. But they cost a bit , sweet header though .
Nice to know about the 2460's . Also to add the 2055's have the biggest y pipe out of all the headers .
Transmission: 4L80E/4L80E
The 2460 y-pipe is now available, and it's an over-priced piece of garbage (sorry, Holley Corp, but you deserved that). It's made to replace the manifolds, y-pipe, and cat on LO3 cars for off-road use only. It's only 2-1/2" after the two sides join, maintaining the restriction the factory put in the exhaust system. Don't take the bait, get the 2055's.
As stated, the 2460's are not the same as 2055's. You can get 2460's with A.I.R. special order, but there really is no excuse for doing that.
Don't modify the 2055 y-pipe to fit your cat! Do as suggested and get the 2118 cat that fits right to it. The '86-'90 TPI single-cat aftermarket exhaust systems are the best single-cat systems available for our cars, stick with that stuff and you won't go wrong.
Car: z28
Ok so hear is the deal what I have on the car now is the stock headers, stock y-pipe that goes into the stock cat. However just this last year I took my cat out and hollowed it all out. After the cat every thing is bran new, and is in a 2 and a half-inch pipe that goes into some kind of off brand performance muffler called an Xcelerator or some like that. I do not understand why my stock cat won’t work. 125$ for just a dum cat is pretty retarded I think. I don’t have to deal with emissions so I personally don’t care about it. So will or will not my stock cat work with this application???
Car: 1989 IROC-Z
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Obviously, a 2.25"/2.5" inlet is not going to fill a 3" outlet, thus it will not work. Either buy a 3" in/out catalytic convertor, or put a peice of pipe in its place as some have suggested.
Here is a sketch I drew in paint to better help you visualize what I am talking about:
I spent $30 for a 2-1/2' piece of 3" pipe expanded to slip over the 2055 y-pipe. Probably paid too much, but it was a shop a couple of blocks from my house, and it saved me the trouble of finding somebody to get it for me cheaper.
You can find a picture of it in the single exhaust pics thread.
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
you could take your stock gutted cat to a muffler shop and get them to expand it
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
40, carberated, carburated, carbureted, cars, headers, hooker, makes, mufflers, oakland, shops, vehicles
