87camaroz28310
close
- Join DateMar 2003
- LocationNew Jersey
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 plane jane with gfx
- Engine350 worked vortec head .515 .515 cam and 1.6 rockers and shorties for now til i can afford the supercomps
- Transmissionsuper t-10 or t-5
- Axle/Gearsauburn with 3.42 stock axles
- Liked:0 Times in 0 Posts
anyone running a lakewood bellhousing with longtubes if you are what hearders are you running because i have heddman and the dont fit and i have tried grinding alot of things and i'm real close but i cant get it to line up.
hmmm...there is a reason hedman says the longtubes work with autos only...won't clear the bellhousing....anyhow, most manual guys run the hooker longtubes.
87camaroz28310
close
- Join DateMar 2003
my buddy got them to work on his 5-speed but he didn't use the lakewood bellhousing. well i'm gonna trade the longtubes for a set of shorties just so i can get it running. then when i get the money i'll buy hooker longtubes. thanks for the info
sweet are they the comps or super comps
87camaroz28310
close
- Join DateMar 2003
thats awesome then thats what i'll be buying
Do you have the part # for the long tube hooker super comps? I have a t-5 and angled plug heads, do you know if they will work with these
think theyre like 2210 or something of that sort, donno bro just look up long tubes for a 3rd gen camaro with a small block by hooker 1 3/4" - 3"
works with angle plugs i have afr 220 with angle plugs
smokefan
close
- Join DateNov 2004
- LocationConnecticut
- Car86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
- Engine383 stealth ram, 305 tpi, 350 tbi, 5.3l
- TransmissionT56, 700r4, 700r4, 4l460
did you have any fitment issues with the long tubes cause some people are saying they have issues with the k member and slave cylinder. i just want to know what i would be up against
Mine ever so slightly touch the A arm on one side but doesnt bother me none, you could grind the a arm a lil or notch the header a hair..really up to you if it bothers you both clearance issues id really say i have none.
