Unknown flowmaster
Old Apr 3, 2006 | 04:19 PM
xfactor200289's Avatar
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
Unknown flowmaster
I just got this flowmaster muffler off a wrecked camaro and I don't know what series it is, is there anyway to tell??????????
Old Apr 3, 2006 | 04:43 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Does it have dual outlets? If so, it's an 80 series.
Old Apr 3, 2006 | 08:21 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
it does have dual out lets, is the 80 series the only one that has dual out lets because the guy I got it from said it was a 40 series, but I wanted to be sure.
Thx for the info
Old Apr 3, 2006 | 08:40 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
If it's a dual-in/ dual out crossflow, it's an 80, otherwise, you'd need a p/n to tell.
Tim sends
Old Apr 3, 2006 | 08:45 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
What he said.
Old Apr 3, 2006 | 08:57 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
How do you get the part number there so many numbers on the muffler
Old Apr 3, 2006 | 10:02 PM
357mag's Avatar
Car: 94 C1500
If it's got a number similar to: 42583, it's an 80 series crossflow muffler. The fourth position should be "8" , signifying 80 series.
Tim sends
Edit: just because it has dual outlets doesn't automatically mean it's an 80 series. Depends on where the outlet is in relation to inlet. If the inlet is on one end, and dual outlets on opposite end, it's not an 80 series.
Old Apr 4, 2006 | 11:17 AM
Car: '72 Chevy Nova
Transmission: TH350
Only flowmasters I've ever seen with one 3" inlet and two 2.5" outlets were 80s series. 3" inlet and one 2.5" out on one side, a single 2.5" out on the other.
Also possible its an older model with 3" on all three, I've heard rumors that those existed at one time.
Old Apr 4, 2006 | 03:50 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Ok the inlet is 2.50 and both the oulets are 2.50
The only # I found on the muffler were
6089547
4574914
4809812
5123502
5444197
Old Apr 4, 2006 | 07:50 PM
357mag's Avatar
Car: 94 C1500
If the outlets are on opposite ends of the case, it's a good bet it's an 80 series. If the outlets are on the same end of the case, it's not going to be an 80 series. Flowmaster, Inc.
Check these out. If it doesn't match one of these, you are SOL.
Tim sends
Old Apr 7, 2006 | 03:53 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Ok I found the # onthe side of the muffler and it is an 80 series.
92camaro350cci
Oct 14, 2015 09:29 AM
Night rider327
Oct 9, 2015 09:25 AM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
Liveaction
Sep 17, 2015 06:29 PM
89fast5oh
Sep 8, 2015 09:55 AM
