Long tubes or shorties...
I've got a '91 camaro, removed smog and a/c so passenger side is pretty open. I've got hedman shorties with 3" collectors already not installed yet. Would I be better off with these or go long tubes? Will there be room to fab a 3" y pipe from the shorties down to the cat?
Car: 1992 Camaro RS
Axle/Gears: Stock
There's plenty of room for shorties and a Y-pipe. But if you go with long tubes, you're probably going to have serious ground clearance issues, though they will give you more power.
I would stick with the shorties.
