Exhaust manifold heatshields
Old May 5, 2006 | 04:59 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I swaping in some headers on my car but i cant get the drivers side heat sheild off. Is there bolts on it or something? I got the first two bolts off of the manifold but cant see the others, im assuming they are under the heatshield. Kinda need a quick response on this one, thanks
Old May 5, 2006 | 05:55 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just pulled the manifolds on my LG4 last night and i didnt have to pull the shield to get the bolts off, just a deep 9/16 socket!
Old May 5, 2006 | 06:03 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Ah ok, did you get to them through the bottom or the top? I have a mirror under the manifold and i dont see the bolts...this is such a fun project lol
Old May 5, 2006 | 08:02 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
well i got all the bolts except the two rear passenger ones and the 3rd to rear drivers side. any tips? ive just been PB blasting them while i contimplate what to do next
Old May 6, 2006 | 10:20 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
When I unbolted them to take the heat shield off I just jammed my hand in there. A few cuts but I still got em off. Just get a pair of mechanics glvoes and push...
Old May 6, 2006 | 01:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Hmmm i had no problem at all getting my ratchet in there and on them, a couple of them it did take a 2' bar on the end of the ratchet to break them loose though...
Old May 6, 2006 | 06:14 PM
Demon355's Avatar
My drivers side came out without a hitch. The passenger side is a whole new ball game. I got all the bolts out except the 2nd last one where the heat shield wrapped itself around the entire head of the bolt. Don't ask how. Took 2 days to get it out with a hammer, tin snips, a really big screw driver, beer and lots of blood shed. Got it off though thats the main thing. Good luck to you, lol!
Old May 6, 2006 | 07:09 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
ok i got the drivers side manifold all unbolted. I still have the 2 rear left on the passenger side. The second to the last one is blocked by the heat sheild so im trying to work around that, and it way back one i donno
Old May 6, 2006 | 10:03 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Wow, i dont see how you guys hae this much trouble getting the manifolds off. Did they maybe put different heatshields on the US cars or something?!?!
Old May 6, 2006 | 10:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
heat shields? I think mine had that goofy tin plate over them, with the air tubes, but it wasn't in the way...
are you talking about those goofy scotch locks? The little piece of tin that's bent to hold the bolt from loosening? yea, that's a PITA. I used a screwdriver to bend them out of the way. Lots of finesse on the rear drivers side ones.
Old May 7, 2006 | 11:00 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
I got the locking tabs bent back pretty easlly. I used a 9/16" offset wrench for the last on on the passenger side. The second to the last on is stripped so tomorrow Im gonna check oout some tools to take it off.
The heatshield that was curved about the spark plug on the passenger side was getting into my way. I couldnt get the socket all the way on the bolt bc of it
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
