92Z Dual Cat setup questions
Old May 23, 2006 | 02:30 PM
ncsu602's Avatar
Long time lurker, just registered today. I have a few questions about a friend's 92 L98. He's noticed a loud rattle from underneath which we suspect is one of the cats going out. He's wanting to replace everything unless it's a heatshield or something simple. All I've heard about from him is headers since I put a set on my 95. My setup is Hooker Super Comp Shorties into a dynomax bullet muffler, then to a mufflex catback with a spintech muffler. We don't have emissions testing on anything but OBD2 and my setup will pass a visual in half the places around.
We're trying to figure out what the best route to go would be and need some advice from the experts. I've searched on here some, but probably not enough. Would it be best to so a single cat 3" setup similar to my 95 or leave the dual cat setup? This is on a basically stock car (K&N and flowmaster) that will stay pretty much stock except exhaust.
The dual cat idea I had was find a set of headers and y-pipe to go with the dual cat setup and run this in place of the cats.
http://store.summitracing.com/partde...auto view=sku
I know it would be a little work, but it seems like a good idea. Any experience with a setup like this? I like this idea because he's thrown around the idea of running true duals later on and it seemed like this would be one thing he'd already have in case he decided to go that route. Let me hear it, thanks!
Old May 23, 2006 | 02:46 PM
yjischoking's Avatar
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
hey you go to state?
and i have no clue which gains more power but what about longtubes?
Old May 23, 2006 | 03:00 PM
ncsu602's Avatar
graduated in '04 with an agronomy degree! Are you still there?
He had thought about longtubes but he's wanting to stay relatively simple, cheap, and keep his groundclearance. That may or may not be possible. I know I've got shorties and an offroad y on mine and I've scraped it before. I'm just looking at options now, he definitely wants headers. I like the option of running shorties with a dual cat ypipe into the dynomax x-muffler and then maybe putting a 2-into-1 reducer to hook to his catback on it now. That way if he decides to go true duals later down the road he's got a good starting point.
I've got a feeling it's gonna be a lot cheaper to run headers with a single cat ypipe and upgrade his catback......we'll see what turns up.
Old May 25, 2006 | 08:27 PM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
keep the dual cats
I would keep the dual cats. This is how to do it. Install a set of shorties with the y-pipe. After that's done, cut the Y off the end of the pipe. Then you can tie in your true duals into your dual cats.
That is how I did mine. I have an '87 GTA that came with a sigle cat, so I scrapped my entire exhaust system. I installed SLP shorties that were Jet Hot coated with the SLP Y-pipe that I cut off Y. From there, I drove it to the shop and had the rest installed. Two cats from a '91 GTA, gutted & straight piped with 2-1/2" pipe all the way back. Total bill, parts & labor was $330, and it even included the chrome tips.
Click here for a few pics.
There's a car above mine on that page that has some really good shots from the underside. If your friend is interested in driving about 2hrs. for some cutom exhaust work, Ricky at Riegelwood Muffler Shop does excellent work.
Good Luck.
Old May 25, 2006 | 10:22 PM
ncsu602's Avatar
wow.....never thought of doing it like that. I think it'd be better this way since he could get a set of quality headers. Skidude, where are you? There's several places up here that do good work. I've got a set of dual pipes (dual outlet muffler) on a ZR2 Sonoma that come out behind the tires. Everyone said this was impossible to do and still have a track bar and full size spare. The guy stared at it for about 30 minutes and 2 hours later I had some pipes.
Thanks for the reply, I like this idea!
Old May 26, 2006 | 04:37 PM
skidude's Avatar
Axle/Gears: 3.42:1
here i am
I'm in Leland, about 3 minutes West of Wilmington. If you're out this way, I'd be glad to let you check out what I've done/had done.
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
onefreakz
May 14, 2018 12:15 PM
Jlanz55
Aug 17, 2015 07:15 AM
redmaroz
Aug 16, 2015 11:40 PM
