LT1 starter
Old May 24, 2006 | 11:10 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
LT1 starter
I recently installed Hooker 2210 headers on my T/A. I used a mini-starter that i was told by the kid at autozone was an LT1 starter. it bolts up, wires up, and cranks. but i keep hearing odd grinding noises and noises like it's binding up under there..... maybe i need to shim it? Has anybody else had this problem? I'm running a scat SFI flexplate, 168 tooth. any thoughts?
Old May 24, 2006 | 11:30 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Did you check the clearance (i.e. shim)?
P.S. What's up?
Old May 24, 2006 | 11:59 AM
TwiSSted's Avatar
Car: 95 Z28....87 T/A
Every stock LT1 I've ever seen has a 153 tooth flexplate/flywheel. So I would doubt it's a LT1 piece. Full size trucks on the other hand use 168 tooth flexplates and have mini-starters. Either way it sounds like it may need to be shimmed.
Old May 24, 2006 | 02:05 PM
Car: 1982 Trans Am
Engine: 383 chevy
gotcha. it's the bigger one, i know that for a fact. and this particular one is actually for a 400, (it's weighted) so being that a 400 is a truck motor..... I'll try some shims. I'll send you a PM mike... so much has happened since i got home from the army. My parents are moving to florida, and i take the first load down tonight. we'll talk then nice to see you're still around.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
