Ok I have a 92' 305 TBI Camaro... After I sit at a red light and then take off, I get a puff of white smoke! I dont get it when I turn it on or while driving... What could me my problem???
sounds like the head gasket, check for antifreeze in the oil.
How can I tell? And for the smoke to come out of the exhaust, and it has to do with antifreeze mixture, wouldnt the head have to be cracked?
If antifreeze in the the oil majorly, itll look like a choc milkshake MM yummy!
mmmmmmmm Yummy... It doesnt seem dirty, but it does seem to be using oil! (no leaks)... Anyother possibilities??? Thanks guys...
i believe another member suggested something similar to this test, You take a pressure tester, Pressurize the cooling system to normal psi like 16-18 i think?, Take out your spark plugs, then Take card board and lay it down beside the exhaust manifolds, Wait like an hour then go crank it , where ever u get antifreeze on the cardboard is where/which cylinder is leaking Just an idea, Guessing it would work
Quote:
WOW! I think Id rather swap the motor before Ill do all that. Thanks for the tip though...Originally Posted by fire350tpi
i believe another member suggested something similar to this test, You take a pressure tester, Pressurize the cooling system to normal psi like 16-18 i think?, Take out your spark plugs, then Take card board and lay it down beside the exhaust manifolds, Wait like an hour then go crank it , where ever u get antifreeze on the cardboard is where/which cylinder is leaking Just an idea, Guessing it would work Any other suggestions? Using oil, Puff of white smoke, only after stop and a short time during accel...
its not really difficult, worst is just pulling the plugs ( rear ones SUCK)
Quote:
No really, it is hard... My car is 100% stock... Last time I changed my plugs I had to change them from under the car! (they all suck) Originally Posted by fire350tpi
Get a pressure tester pump it up to about 15psi leave it alone for a while. Did the gauge drop or stay around the same. If it droped look for leaks then if nothing is spotted turn the car on and look for white smoke. Was the coolant full or low. They also make a tool that uses a chemical that turns blue if their are carbon particles in the antifreeze. Typically a pressure test or cylinder drop down test would give you alot of information. However if its blowing white smoke after a pressure test it has a deffinate leak.
Run engine with cap off and look for bubbles in radiator or the overflow. Needs to be warm up. If you see bubbles then your head gasket is bad.
Look in the radiator when the car is cold looking for oil sheen.
Drain the oil and look for milk shake or water
Oil and water looks great... It hasnt used any water what so ever... It is using oil, but oil is clean... Originally Posted by kurfbird
Run engine with cap off and look for bubbles in radiator or the overflow. Needs to be warm up. If you see bubbles then your head gasket is bad. Look in the radiator when the car is cold looking for oil sheen.
Just a note, this has been going on for awhile now... And it still hasnt used any water at all. Just oil...
koolbreeze92
close
- Join DateJun 2006
- LocationHaileybury, Ontario,Canada
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1992 Brilliant Red Metallic with T-
- EngineLB9 305 TPI
- TransmissionMD8 4 Speed Automatic
- Axle/Gears2.73....Paint peeler
- Liked:0 Times in 0 Posts
Go and put full coverage on it and wrap it around a telephone like the picture u have.... then claim it and buy a newer one....lol.
I had that problem with a 87 trans am with a 305 and it ended up being a crack head but i was burning a gallon of antifreeze per tank of gas.thats all i can help....sorry
Quote:
LOL! Now thats funny! Originally Posted by koolbreeze92
I sure hope its not cracked. O well guess it will give me a reason to get rid of it or get another motor... (I have no idea on how to work on heads...)
I was reading an article in Camaro Performers and they had a project 3rd gen and thier car is pretty much doing the same thing... They replaced the valve stem seals. Could this be my problem?
or u sure it blue smoke not white?
Quote:
Maybe a small hint of blue, but from what I can tell "white"... The Camaro Performers car was also white smoke. And all it did was burn oil, just like mine. Its really hard to tell exactly what color because its only when I sit and then take off is when I can get a look at it in my rear view...Originally Posted by alpine247
or u sure it blue smoke not white? Member
then it blue that where your oil is going you need replace your valve seals or your piston rings
Quote:
Is that hard or worth my time / money? Or should I just go get another motor and bolt in? And your sure this is my problem?Originally Posted by alpine247
then it blue that where your oil is going you need replace your valve seals or your piston rings Member
while the piston ring yes u have to take the engines out and replace the rings but if u do that i just rebuild the engine. but the valve seals is a differnt story it take a good day or so but it hard if you dont know what you doing
and yes this is your problem
Then I will probly get another motor... Thanks for your help Originally Posted by alpine247
while the piston ring yes u have to take the engines out and replace the rings but if u do that i just rebuild the engine. but the valve seals is a differnt story it take a good day or so but it hard if you dont know what you doingand yes this is your problem
