exhaust joints
Old Jul 2, 2006 | 08:53 PM
eddie jr's Avatar
exhaust joints
Just wondering, di you guys normally weld your slip fit exhaust joints or just use clamps. All the cars I have ever worked on usually I just see clamps, but thought i would ask since i recently heard of someone welding them.
The reason i ask is that i just put a magnaflow cat on (direct fit) and there is a slip fit joint on the front. It is not the greatest fit and even with a clamp it appears to be leaking a bit. The asked the guy at the rent-a-bay if it should be welded and he said "no no, just clamp er down tight and carbon will plug up any leak". I thought that was a bit hokey so i thought i would ask here (since i don't do a lot of exhaust work).
thanks.
Old Jul 3, 2006 | 12:13 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd weld it. Leave some joints on your exhaust, so you can remove it , but weld most joints.
Old Jul 3, 2006 | 12:51 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Weld everything, clamps suck.
Old Jul 3, 2006 | 09:15 AM
eddie jr's Avatar
So what would I do if i ever needed to remove or replace the y pipe? I wouldn't want to have to buy another cat since this is a nice stainless one.
Old Jul 3, 2006 | 10:08 AM
Engine: 450HP 355
Transmission: TH350
Hack saw, Sawzall, exhaust chain cutter, etc... If youre like me and you do all your exhaust work yourself it takes a little effort but atleast you did it yourself
It's just metal..It can always be re-welded
Old Jul 3, 2006 | 10:35 AM
eddie jr's Avatar
won't it just rust out at the weld though? That seems to be where exhaust goes first since it is bare.
Old Jul 3, 2006 | 10:49 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Ceremic coat it.
Hey how do you guys weld the top of your exaust tubing....kinda hard to get the gun between the floorboards and exaust tubing.
Old Jul 3, 2006 | 12:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Do what I did... Weld the catback all together, but weld a 3-bolt header flange on the end of the catback and the Y-pipe, where they meet up. If you need to drop the exhaust or Y-pipe, they easily come apart. Those flanges, with good gaskets, don't leak like clamps will.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
starfinder
Oct 25, 2015 10:40 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
bubbaz28
Sep 18, 2015 02:09 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
