headers without airtubes?
Old Jul 23, 2006 | 10:16 PM
L.I.N.Y.92CAMARO's Avatar
I looked at the chart at the top of the page and they all have air tubes. If there any shorties that come with a y-pipe that doesnt have any air tubes?
Im looking to spend roughly $400.00.
Thanks,
Old Jul 24, 2006 | 12:35 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The same companies that make headers with air tubes also make headers without airtubes.
Old Jul 24, 2006 | 12:53 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Call, alot of companies carry more than what you think they do, or what you see/know of.
Old Jul 24, 2006 | 01:01 AM
honkeytonk_man's Avatar
Car: 1988 IROC-Z
Engine: e-tec headed ZZ-4 350
Transmission: t56
Axle/Gears: 9 bolt 3.7 posi
I am running heedman headers, they make 3rd gen shorties without air tubes. They fit really well and don't leak. I like them better than the edelbrock air tube headers I had before. Also they are cheap, be warned the y pipe they sell will need work, but it where it goes from two into one they reduce the tube from 3" to 2.5" so if you have a 3" intermediate pipe you will have to have a muffler shop replace that section.
Old Jul 24, 2006 | 01:29 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
buy the 2055's, have your 3in y, cut off the airtubes, and weld the primary tubes shut...
Old Jul 24, 2006 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Old Jul 24, 2006 | 08:39 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Yeah, because that looks good.
Isn't there an option out there for those of us who don't want air tubes, but refuse to settle for a set of headers with a bunch of welded-up holes?
I'm considering a set of Heddman 2460s and having a local shop make a y-pipe for me. It's unreal that nobody makes a good set of headers with a good y-pipe that doesn't have air tubes.
Old Jul 24, 2006 | 08:47 AM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
SLP has a set that are non-air equiped.
Old Jul 25, 2006 | 10:32 PM
My brother has a 1994 suberban TBI and his manifolds looks the same as ours. Now would his headers fit on our cars because you can get a pair of headers coated chrome for 150 bucks for his truck?
Im thinking about ordering a set and seeing if they fit or not.
The only thing you would have to get a shop fab. a y-pipe or do it yourself but still its cheaper and so much better looking if they do fit.
If anyone knows please let me know
Thanks,
Old Jul 26, 2006 | 11:56 PM
Kevin91Z's Avatar
AIR tubes are part of the emissions package, and its a federal offense if you modify or disable the emissions systems. Therefore, selling headers for street vehicles without AIR tubes is technically illegal. That's why they're so hard to find.
Originally Posted by LINY92Camaro
My brother has a 1994 suburban TBI and his manifolds looks the same as ours. Now would his headers fit on our cars because you can get a pair of headers coated chrome for 150 bucks for his truck?
The manifolds look the same, but the headers are routed differently to clear the frame. They wont fit in an f-body. Truck headers are cheaper because they dont have AIR pumps or AIR fittings (most of them).
Old Jul 27, 2006 | 07:40 PM
Wow thats a big let down... But they can sell them as a "off road" headers just like they do with offroad Hpipes for mustangs which gets rid of the cats.
Does anyone know any part numbers for thirdgen shorty with a y-pipe with no air fittings??
Thanks,
Old Jul 27, 2006 | 08:57 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
I think you mean Hooker 2460's....you can get them and they also make a y-pipe for them as well....$200 for the y-pipe.
Old Jul 31, 2006 | 01:22 PM
89BlueRSCamaro's Avatar
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
headers with no AIR tubes is not illegal as long as you can pass emissions...better yet nothing is illegal unless you cant make standards...
Old Aug 5, 2006 | 12:11 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
try SLP 1 3/4
SLP Performance Parts, Inc.
Old Aug 6, 2006 | 03:44 PM
Kevin91Z's Avatar
Wrong! Read what I said above. Its a FEDERAL offense to modify or remove your emissions equipment, regardless of your state's emissions tests. Removing your cat, removing your air pump, or removing your air fittings IS illegal. But youre not likely to get caught unless your area does smog checks.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
