how do cut outs work???
Old Sep 17, 2006 | 03:13 PM
FireBirdBoy's Avatar
ok i have searched over and over again and all i find is threads on what cut outs to get but i still dont understand what a cut out is and how it works? is it just a hole in the exhaust that lets more exhaust out of the pipe, also how does an electric cut out differ from a cut out that you have to get under the car to "plug" and "unplug" so any help is great thanks guys
Old Sep 17, 2006 | 04:05 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
a cut out is a "Y" in your exhaust system. idealy it is placed just after your "y"pipe before your cat. the "y" faces backwards. when closed it does NOTHING, it just routes the exhaust out the back like it was not even there. when it is open it dumps the exhaust out right behind the front wheels, before the cats, before the mufflers.
depending on how good of an exhaust system you have you may or may not see any HP gains from this. the main thing is that you will have LOUD exhaust. it is mostly an intimidation thing. some punk is reving at you at a light, you flip the switch and slam the gas "VROOOOM" and he is put in his place.
electric versus manual:
an electric cutout has an electricity oporated celenoid that opens up the dump flap, and closes it again. a manual cutout is done by you physically. you crawl under the car and remove the 3 wingnuts and pull the block off flap off the car. and then put it back on later. i would go with an electric. back in the day they also had cable oporated and vaccume oporated ones. i don't know if you can still get those kinds though.
Old Sep 17, 2006 | 04:10 PM
thank you so much that really does clear things up for me, sounds like a pretty decent idea thanks again man
Old Aug 30, 2007 | 10:49 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: how do cut outs work???
real quick. do we face the cutout down or is it parallel wit hte rest of the exhaust?
Old Sep 2, 2007 | 12:55 AM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
parallel, if you face it down and you bottom out your gonna be paying for a new cut out and possibly more
Old Sep 7, 2007 | 03:13 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
there is some good eletric (12V) flaps to bolt to the 3 bolt flange on your cut out, EXTRA LOUD WITH A FLIP OF A SWITCH lol
http://www.jegs.com/webapp/wcs/store...letric+cut+out
^LINK TO ELETRIC CUT OUTS ON JEGS.COM^
you can also get the physical cut out from Jegs
also check e-bay
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
