Does this look right?? pic inside
Old Sep 21, 2006 | 05:06 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
this cant be right, i bought the car like this and im scratching it all the time and i want to know what needs to be done?
Old Sep 21, 2006 | 05:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
is htis a stock of aftermarket exhaust? the should be a hanger going from the trans mount? to the cat.
Old Sep 21, 2006 | 06:02 PM
gottfuel's Avatar
there is a hanger from cat to trans..as far as i know this is stock
Old Sep 21, 2006 | 08:26 PM
EvilCartman's Avatar
Car: '82 Z28
If it's stock, it needs to be probably 3-4 inches higher.
Old Sep 21, 2006 | 08:45 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Although I don't know why it is in the condition that it is in. wazzup?
Old Sep 22, 2006 | 11:22 AM
gottfuel's Avatar
you know im not sure, im thinking now that it has somthing to do with the way my engine sits,. i was looking at it and the passengerside mount seems to have a bolt missing also it sits a lil to the back/side1
so i wonder if i fix that problem if it will lift that pipe a lil higher!
Old Sep 22, 2006 | 11:26 AM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
I was gonna say, it looks like your engine mounts are toast. If you can, open the hood and get someone to sit inside the car and rev the motor and see how much it moves around in there. I can guarantee thats the probem.
Old Sep 22, 2006 | 09:09 PM
gottfuel's Avatar
yea gtajoe your right my mounts are toast!
so..what causes this to happen., is it just that they get old an rott or is somthing causing this?
Old Sep 22, 2006 | 09:50 PM
Car: '82 Z28
Pretty much, plus if they're constantly soaked in oil from leaks over the years.
Old Sep 23, 2006 | 05:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might consider poly replacements. Even with the mounts shot, the exhaust looks low to me. Check the cat hanger for adjustment. As is, be careful of a snake crossing the road or you'll lose something.
JamesC
Old Sep 23, 2006 | 06:07 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
that's lower than my longtubes! it's lower than the sub frame!!! bad mounts would never hang that low you are talking about over a 3" lower than normal height, the oil pan would be on the frame. and BTW the eng. mounts only mount with 3 bolts to the frame. what it looks like to me (with out knowing anything else and since the picture only shows one small part) like some one has shorty headers on the car and fabbed the stock y-pipe to fit.
Old Sep 25, 2006 | 03:18 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
Nice Tires.. LOL,
Thats Def. a problem, are the Stock manifolds on there? or headers?
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
mud runner
Nov 2, 2015 07:30 PM
64Chief
Sep 12, 2015 08:05 AM
gt4373
Sep 9, 2015 10:29 AM
