Borla owners, how are the tips mounted to teh body?
Old Oct 7, 2006 | 12:26 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I bought a used Borla system the other day and we only partially installed it, basically welded the over the axle portion and bolted the tips to the bolts that hold the rear bumper support on using metal strip with holes in it. (didnt' have time to weld on the hangers)
Well, the metal strips that were holding the tips up broke tonight, so now the muffler is bouncing around.
What method and material is supposed to be used to support the tips?
I searched on Borlas site for the installation instructions, but they don't have instructions for our cars online.
Old Oct 7, 2006 | 05:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm not a Borla owner, so I'm useless. However, I am surprised, given Borla's rep, that the tail pipes themselves didn't include a provision for hangers, like the OEM versions.
JamesC
Old Oct 7, 2006 | 08:35 AM
Zepher's Avatar
There are provisions for hangers on the tailpipes but I don't know what they used between the body and the tailpipes to hold them up..
The muffler wasn't on a car when I bought it, it was just in my friends backyard, he got it from someone else.
Old Oct 7, 2006 | 01:59 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
Use a short peice of rubber.
Old Oct 7, 2006 | 04:09 PM
Zepher's Avatar
where would I look for rubber that is thick enough not to tear easily?
Old Oct 7, 2006 | 05:49 PM
JamesC's Avatar
GM, no doubt, still makes the original hangers (driver and pass), both of which incorporate rubber.
JamesC
Old Oct 7, 2006 | 08:35 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
if you have a welder, go to Advance or AutoZone. They have universal hangers which should work fine if you can find a way to bolt them to the underbody
Old Oct 8, 2006 | 12:08 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
or even side walls to old tires work. if you cut them clean they look just like the hangers
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
neekolzun
Aug 24, 2015 04:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
