Hooker 2055's & Alt brackets...
Old Dec 6, 2006 | 12:01 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I helped an experienced mechanic this weekend install my Hooker 2055's.
I am legally blind and while I have done some things on my car, sometimes I have to pay those more capable.
Anyways, he says there were 2 brackets holding the alt to the stock exhaust manifold driver's side (91 TPI). I used Breslin header bolts, and no studs were provided. He said I would need to contact the header company and get studs to remount the brackets or the alt / ac would begin to shake and break the main bracket...
In all my research, I've not read or seen anything about this... Can someone please advise?
Rafael
Old Dec 6, 2006 | 08:10 PM
bigjay89gta's Avatar
Car: 89 GTA
After I installed my hooker 2055's I left my alternator bracket off and on the way to work. The Alternator broke off. So I would definitely suggest getting it fixed. I just used a longer bolt with spacers in it and it works perfect. Goodluck
Jason
Old Dec 7, 2006 | 09:50 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not totally familiar with the TPI bracket mounting, but you should be able to use the original manifold bolt with the supplied spacer between the header flange and the bracket.
Old Dec 7, 2006 | 10:07 AM
luvofjah's Avatar
I didn't get a look at it before he took it off.
I do have the stud, but it's not shiney and new
Thanks for your replies and help.
Rafael
Old Dec 10, 2006 | 03:14 PM
luvofjah's Avatar
I found this.... it's nice and shiney!
http://www.jegs.com/webapp/wcs/store...84456_-1_10363
Someone with experience chime and and let me know if that will work, I think it has the same thread size as the breslin's I installed (I threw the box away and can't remember).
Rafael
Old Dec 10, 2006 | 08:24 PM
luvofjah's Avatar
Don't mind me, I enjoy typiing to myself...
I found this thread.... https://www.thirdgen.org/forums/tech...headers+alt+ac
It would cost me $100 in cab rides to go to all the places to get this done...
I still have the stock bolts, they're 3.5 inches... that jegs one is 4... but the sleeve looks to be lose fit... so it wouldn't work...
Raf
Old Dec 11, 2006 | 09:46 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Raf
i used the stock manifold bolt for the alt./ps bracket and it works great i havent done anything about the two ac brackets though and havent had any problems. ill get to that though.
Last edited by maroon88iroc; Dec 11, 2006 at 09:48 AM. Reason: Automerged Doublepost
no green
Jan 9, 2016 09:22 PM
BDR
Nov 7, 2015 03:05 PM
thekurlyone
Sep 30, 2015 12:54 PM
J.C. Denton
Sep 21, 2015 04:23 PM
Slush92RS
Sep 2, 2015 08:56 PM
