Ed Quay 1 7/8 for stock chassis cars
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
just got these today. Ed just started offering headers for stock chassis cars or those not running an aftermarket k memeber. The only thing I had to do was change to moroso motor mounts because my clam shells didn't work. For the money, these are the best headers on the market for those that need larger than 1 3/4 or are tired of Hookers leaking o-ring seals. These were mounted to my test mule. The headers fit straight/angle plug heads and any mini starter you can think of. You can even use a oil filter mounted to the block only it has to be a short one. They also have enough room for a kick out oil pan.
I'll update you on the exhaust when I have the 3.5 inch oval done.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
what upgrades did you get? Are these specifically for a stock chassis car? I have a tube k member and a arms I am sure they will fit with that front end I was just curious about everything. I might be calling Ed Quay very soon..... again. Thanks
Car: 1982 Camaro
Engine: 555 BBC
Ed quay has form you fill out so they know the specifics of your car. My upgrades where tube size (30.00) and I had the welding finished on the flanges They usually don't do that becaus ethey want you to set the angle since most people they deal with have tall decks and non standard heads etc...
Car: 82z28
Engine: 406
Transmission: th350
I know you said kicked out pans, but any specifics on which pans may cause trouble? I plan on running cantons road race pan?
mini starter and short filter...possibly motor mounts? I can deal with that.
Hurry and get some ground clearance photos...i cant really afford what Stahl wants for his headers...
Car: 1982 Camaro
Engine: 555 BBC
when I spoke with Ed Quay, they told me that there isn't a pan they've seen that wouldn't fit between the headers. I have the Moroso with the kickouts and have no issues at all. The motor is dynoing next week so I'll have installed pics or I'll use my mock up engine to show clearance. Sometime next week.
Car: 1982 Camaro
Engine: 555 BBC
Hedman and Hooker take note!!
this is how headers should fit. No "clearance" issues at all. They tuck under the car like 2210's and mine have 3.5 inch collectors. With the solid mounts it gives the headers room also. Take a peek for yourself. the only issue now will be exhaust but i think i am going to do oval.
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
1BADRZ28,
If you wouldn't mind, could you take a measurement from the bottom of the block (oil pan rail) to the bottom of the primaries? I'd like to find out how far those headers would hang below my 8.25" deep Moroso pan.
Thanks. --Neil
Thanks. --Neil
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
They look nice and a much better price then I paid to have my set custom built.
But I am not at all of a fan of a slip on collector. Those collectores are slip on and attach with bolts. Right?
Car: 1982 Camaro
Engine: 555 BBC
yes, they attach with bolts.
Neil87z28 the headers measure 8.5 inches from the oil pan rail
Are you going to use them on the street with exhaust? Curious to see how bad they will leak or are you going to seal them up with sealer?
Car: 1982 Camaro
Engine: 555 BBC
This is my street strip car. I am curious why you think they will leak? They have a machined flat surface that goes against the head and I will be using gaskets. I know most people with race headers use silicone. I am not a big fan of it as it looks rediculous under the hood. The collectors surely will not leak unless Hooker super comps leak as they have a tube that slides into the collector also.( I never had an issue with super comp leaking.) I'd rather have a machined flat surface than an o-ring seal with bent flages that are likely to happen over time like the rest of the headers on the market. I am going to seperate the tubes from the flange as it makes it easier to get the headers in and out.
I'd rather have solid mounts than have the factory rubber ones rip out. Plus, you actually have more room twithhe clam shells out of the way and they look nicer I think. This by no means is a car that will driving cross country.
At least these give people another alternative that need larger headers without the huge pricetag. I'll post pics of my oval exhaust once I get it finished. I have to fab up a u bend to go under the trans crossmember. Dr gas doesn't make on that way. His bends are only in the plane.
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Thanks again. --Neil
Car: 1982 Camaro
Engine: 555 BBC
once,I take them out again I'll mic them. You can order them with the stahl pattern if you want. I just didn't want to deal with adapter plate. I believe the it the measuremant should be 1.75 in or just over it. If you are looking for maximum flow adapter plates would be the way to go.
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
dam man. the more pics i see the more i want to get them. oh well ill just have to wait untill after i do my trans. what is the turn around time for them from when you order them.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Those headers look amazing! The fit looks great to but I'am wondering why you went so big on the tubes? Like how much HP can 1 7/8 support compared to say 1 3/4 headers? Also what are you planning for the rest of the exhaust from the headers back?
Car: 1982 Camaro
Engine: 555 BBC
the motor should dyno in the 600's and will also have a nice healthy hit of nitrous. I was just planning for the future. Exhaust is 3.5 oval.
Car: 82z28
Engine: 406
Transmission: th350
I would still like to see a ground level clearance photo, with the car on its wheels. Let me know when you get it on the ground.
Car: 1982 Camaro
Engine: 555 BBC
It will be a while as I just put an order in for a Spohn k member. Once I have that and t he engine back it will be on the ground.
What about the collectors? Are you going to just wed the exhaust to the collectors or add on a 3 bolt flange?
Car: 1982 Camaro
Engine: 555 BBC
I will be adding the flanges otherwise the oval exhaust pipe I have ordered is slip fit. I am about a month away from fabbing up the exhaust totally.
I had a mini starter installed during mock up and someone could possibly use a stock starter as there was a lot of room. The oil filter needs to be a short style filter but can be left in the conventional spin on spot.
Sounds good.
Not sure about a small oil filer though. I really like my HP4's..
Will be looking forward to seeing how your exhaust comes out. Everyone has different ides on how to do things.
I used duel 3" into a 4" single and have tons of room but I also relocated my frame rails to do so. But then my car is also lowered three inches.
Car: 1982 Camaro
Engine: 555 BBC
just updating the thread. I fabbed up the frame rails with 2x3 tubing and mocked up the oval exhaust (the first 48 inches.) on both sides. With the oval exhaust, I won't need any bends as the headers point straight back and positions the exhaust right under the seats and will use all straight tubing with Dyno max 3.5 inch bullets by the rear end. The oval exhaust is only 2 1/4 inches thick and spreads 4 1/8 inches. Road clearance will be superb as it only hangs less than inch below my fame rails which are direct extensions from the transmission crossmeber frame that I removed. I found a Moroso oil filter that fits. Plus, my trans brake solenoid has plenty of clearance for my th-400. All I have to do is fab up the tranny crossmember that basically uses the Spohn th-400 crossmember I had with the ends cut off and some 5 inch channel for the exhaust to run through. Once I get the car assembled with the new engine,transmission and exhaust I'll post completed pictures.
The headers will work with 3 inch exhaust bolted up but my plan was to have road clearance so I had to do some custom work to get around the low hanging under the crossmember 3inch I had before and get the exhaust to run as straight as it can and it seems to be working perfectly.
There is a company in IL that sells oval exhaust cheaper than anyone else. I'll have roughly under $200.00 for the piping and 3.5" oval to 3.5" round transitions for the bullet mufflers. They sell exhaust systems for NASCAR so you need to look at the charts and figure what you need. They sell elbows too but only in "plane" not the hard ones that look like a "U". Website is not that user friendly and neither is the tech guy. There piping is also different sized(height and width) than everyone elses so other oval accessories won't work with their tubing.
www.boyceindustries.com is the exhaust piping company
Post some pictures of your new frame rails. How did my idea help you out?
Some of us want pictures!!!
Car: 1982 Camaro
Engine: 555 BBC
I attempted to bend up the steel to fit but lying on your back isn't the greatest so I opted for the 2x3 tubing which made the job a little easier. Once fully assembled I'll post pictures because I can't get that great of pictures with my camera because it shoots way wide. Here is one I could get.
Car: 1982 Camaro
Engine: 555 BBC
Finally fabbed up the crossmember last night. It's made from 1x3 square tubing and connects to the 2x3 frame rails that I fabbed up. Just waiting for my tranny shield to come from CSR to assempble engine and tranny in the car. I'll have complete oval exhaust pic's up soon once engine is installed. I'll post a pic of the crossmember tonight. My camera phone pic stinks.
Car: 1982 Camaro
Engine: 555 BBC
ok, here is the crossmember finished and installed. I used part of the Spohn crosssmemebr I had to mount the transmission and torque arm. I figured I might as well use the pieces I have to save time. The cossmember is fabricated from 1x3 square tubing with plent of room for 4.5 inch oval if my car ever come close to using that type of exhaust. As you can see my exhaust will be tucked up next to the original transmission mount which will give a lot of clearance were many people scrape. I have not assmebled the car yet as I am waiting for the CSR tranny shield. Once that arrives I'll assemble the car entirely and post pic's if anyone is interested.
I apoligize for the brake line that is not re-routed yet and the filthy bottom side. I defintely need to clean that up this weekend. The original owner seven years ago never used valve cover gaskets and I only cleaned the front subframe and some parts of the bottom.
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
Very cool. Has anyone used these with a stick? based on the price, This is the header I would choose. 1BADRZ28. the x-member looks good, I think I'll build mine like that. Keep the pics coming...
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Re: Ed Quay 1 7/8 for stock chassis cars
Very nice Jim! Custom crossmembers are really the only way to go. I think those headers would work just fine with my T56 from the looks of that...
Car: 1982 Camaro
Engine: 555 BBC
price was right, when you conider the options or lack there of in that size of a header. I'll post up the painted and installed pics this weekend.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
So they make 1 3/4 also? Do these hang any lower or higher than the hooker 2210's?
