Maximum ground clearance with 2210's and a T56!
Old Mar 4, 2007 | 07:53 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Hi everyone,
I've got some pictures of my latest project, a new exhaust system for the Trans Am that doesn't sacrifice ground clearance with the Hooker long tube header.
The Y-pipe that I've fabricated is going out this week for thermal barrier coating, and that picture will be later this week. In the mean time, you can see more pictures at http://www.ws6transam.org/Gallery under the random stuff album.
I've designed my Y-pipe specifically for the Long Tube header, the T56 transmission, the thirdgen body, and Skulte's new longtube crossmember. It also tucks up tight enough to allow for use of the Unbalanced Engineering decoupled torque arm design, which you can see part of the crossmember in the above picture. It's better than factory clearance, except at the collector of the headers themselves. I can't do much about that!
Old Mar 5, 2007 | 09:32 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Very Nice!
I made one similar..
https://www.thirdgen.org/forums/exha...er-2210-a.html
Old Mar 5, 2007 | 09:09 PM
ws6transam's Avatar
Originally Posted by onebad82z
Looks real good under there! I have a Flowmaster merge sitting here too but I couldn't use it because of the decoupled torque arm crossmember and driveshaft loop that got in the way. It tightened things up and forced me into fabricating my own merge. However the Flowmaster merge is indeed a nice piece, I kind of wish I could have used it. Now I need to return it or sell it to someone on thirdgen.org!
...no I'm not making any extra Y-pipes for sale. There's 12 hours and $140 in materials in there!
Old Mar 6, 2007 | 08:02 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I know what you mean..I still have to build a new loop to go with the crossmember for my car as well. Wouldn't be so bad if there was more room under there!
I have around 4hrs into my y, but I was able to use the already made FM merge, thankfully.
Old Mar 6, 2007 | 12:01 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Looks very nice ws6, I bought one off someone and me and my brother just got done cutting and welding it up to fit. Took a solid 4 hours but it turned out pretty good.
Attached Thumbnails Maximum ground clearance with 2210's and a T56!-03_06_07_1239.jpg
Old Mar 8, 2007 | 08:54 PM
ws6transam's Avatar
There you go, that'll work. My Y-pipe is at www.zoofactorycoatings.com right now getting double ceramic coated.
Old Mar 18, 2007 | 09:45 PM
ws6transam's Avatar
I got the Y-pipe back from http://www.Zoofactorycoatings.com this week!
You can see more pictures of it here: http://www.ws6transam.org/Gallery
Here's the installation pictures that show the Y-pipe in relationship to the rest of the car's underside. No it's not a Chip Foose clean underside, but I've never gone for trophies that rely upon mirrors of the chassis... Forgive me, but it's a Michigan car with Ziebart rustproofing from the early eighties.
Y-pipe merge collector in relationship to the crossmembers.
Here you can see the crossmembers and in the shadows, you might be able to see the new Moser 12-bolt axle assembly.
Closeup of how the exhaust merge collector clears the driveshaft loop. You can also see the end of the decoupled torque arm and the white Chromoly driveshaft with spicer 1350 series U-joints.
Overall underside of the Y-pipe and its relationship with the decoupled torque arm crossmember.
Old Jun 3, 2007 | 09:56 AM
BOTTLEDZ28's Avatar
Transmission: A4
Re: Maximum ground clearance with 2210's and a T56!
very nice design there. Kinda looks like the one I made a last year for my setup. How do you like the coating on the ypipe? I have never heard of that company before and I am looking for a place tohave my longtubes coated.
billybob6110
Sep 23, 2015 01:30 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Glowsock
Sep 5, 2015 07:48 PM
tonys91rs
Sep 2, 2015 07:07 PM
