Y pipe cut outs???
Old Mar 10, 2007 | 01:54 AM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
Y pipe cut outs???
is there enough room to weld in some electric exhaust cutouts in the y pipe?
ive got a set of 2.5" electric cutouts i saved off another car, Ive been thinking about this but dont know how much room there is to do it. has anyone else done this or thought about it?
I drew out what i was talking about, sorry if it looks bad
Old Mar 10, 2007 | 04:28 AM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
even if they were full size headers i dont think there would be room...
and putting one right after the y-pipe would pretty much do the exact same thing...
Old Mar 10, 2007 | 08:02 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I wouldnt recommend doing it the way you showed, it will vent the fumes under your hood, and its bad for your car sucking it back in, and bad for you breathing it. A better place to do it is just before the catalytic converter. But again you run into clearance issues. Best would be to point it inwards under the car which would cause exhuast probs, but it would also be possible to point it outward with some clearance probs.
Old Mar 12, 2007 | 06:42 PM
smallblock383's Avatar
Car: 1991 Z28
Engine: 383 TPIS Mini Ram
Transmission: D&D Perf Viper/GM T-56
Axle/Gears: 3.73's Eaton Posi
My first attempt at cutouts lead me to destroy a Hedman y-pipe that came with my hedders. (that was trying to install one just under each collector. Then I got a new y-pipe and just put one right before my y-pipe entered my cat. They are all right....its gonna do the same thing. Now I just reach under the car, undo three wing nuts, and I'm open. I think we have all tried this collector excursion on our third gens..and it seems we all end up doing the same thing.
Old Mar 12, 2007 | 06:49 PM
Car: 1991 Z28
As far as having clearance problems in that spot...there are none. My car is at stock ride height and the dump doesn't sit any lower than the cat does. It is facing out towards the lower passenger ground effect. I wouldn't face it in towards floor boards for one reason, who wants to reach under a hot exhaust pipe to undo three wing nuts. Thats just a 3rd degree burn waiting to happen
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
LittleFranks
Aug 20, 2015 03:55 PM
