building my own setup...
Old Mar 27, 2007 | 07:38 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
Okay, so i'm putting together an exhaust to go with my new engine. and Ive been having a lot of trouble finding exactly what i want.
headers with a.i.r. rail and 3" outlet (i need it to pass emissions for one more year)
y-pipe with 3" in and out
I've scoured summit and other online performance shops, and I can't find anything, so i have some questions.
1. am i overlooking some shop that has the above stuff?
2. do I really need an a.i.r. rail to pass emissions?
3. I want to run a 3" main pipe, so if I can only get headers with 2.5" outs then hook them (properly) into a 3" in and out y-pipe how much would that effect the flow?
i know you can get air rail kits and put them in yourself, but i dont want to do that unless absolutely necessary. also, would an exhaust shop be able to fashion me a custom y-pipe if i can't find one?
ps it's an 84 sport coupe with a 350 (new motor).
thanks for any help.
-Tony
Old Mar 28, 2007 | 01:34 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: building my own setup...
the exhaust is only as good as its smallest diameter point. as far as i kno they dont make 3" collectors on the shorty applications and the Y's are 2.5" in and merge to a 3" collector, if u want 3" collectors u gotta go long tubes. shorties are a waste compared to longtubes and will prob cost u less to run true duals. i ran mine for 320$, and thats 3 inch collectors, long tubes, mandrel sbends, 3 inch mandrel xpipe and 3 inch highflow force mufflers.
if u get a custom y make sure its mandrel bent which most shops dont do, a edelbrock/slp shorties with 2.5' collectors and 3 in Y with a 3" catback can support 450hp, u should be fine, just get ready to fork over alot of $
Old Mar 28, 2007 | 11:40 AM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
Originally Posted by dc_sniper9130
2. do I really need an a.i.r. rail to pass emissions?-Tony
i hope someone can answer that because im about to get the slp headers and i dont want the A.I.R.
Old Mar 28, 2007 | 04:49 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Physically no....the car will prolly pass without (mine passes here in Canada) but check your local regulations because there may be a visual inspection.
Old Mar 28, 2007 | 04:57 PM
Car: '84 Camaro SC
yeah, they dont do the under-hood check here. plus i'll be having the emissions requirements for the carbed v6, so i dont have much leeway
Old Mar 28, 2007 | 09:05 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
My 86 "V6" Firebird passed the sniffer test with flying colors after I had swapped in a 350/T5 combo and I got rid of the A.I.R. set up. I used a factory dual cat y pipe.
Old Mar 29, 2007 | 11:28 AM
Engine: 305 5.0 LG4
im gonna have to check....cuz i dont mind the air thing but im trying to de clutter my engine bay a lil and i noticed that alot of those hoses are linked to the stock headers
Old Mar 29, 2007 | 12:26 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
The hooker 2460 shorty has 3" collectors.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
