Lowered 3rd Gen with LONGTUBES (Pictures needed)
Old May 4, 2007 | 02:19 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I am looking for anyone with long tubes that has lowered their car...either with eiback 1" front and 1.25 rear or coil-overs (which is what i will be buying).
Pictures of any cars lowered without the longtubes would be appreciated too, so i can get a look as to how my car will be with lowering involved.
Thanks much everyone.
Old May 4, 2007 | 02:31 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Re: Lowered 3rd Gen with LONGTUBES (Pictures needed)
i have an 86 trans am, i have eibach sportline springs, which are lower then the prokit and run hedman 68460 long tubes with true duals. here is a pic of the headers underneath. i included a video as well, shows how low the duals hang, and how it sounds, i run hedman extensions, summit h-pipe, and moroso spiral mufflers with turn downs.
http://videos.streetfire.net/video/e...20011f2e7f.htm
Old May 4, 2007 | 02:38 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Yous tuck VERY well compared to alot of others on here. Do you have any pics away from the car but still looking at the longtubes. maybe like 5-10ft away.
Also how is scraping and bumps? How big of a bump (not that it would be accurate) do you have to hit to hit your longtubes or have you never hit them?
Old May 4, 2007 | 03:14 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Those do tuck tight. I've seen Hookers tuck that tight as well. I thought the Headman's were a PITA to install though.
Old May 4, 2007 | 04:57 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I dont think ive ever seen hooker long tubes tuck tight, they always hang down.
I have hedman longtubes and the pro kit.
here is a pic of mine, not the best pic. look at the electrical linse hanging underneath, the 2 half round protrusuions are the headers, in the middle is my t56 crossmember I made to run 3" duals, and lastly that is your standard sams cola can sitting on the ground.
In the pic I dont have my fenders, hood or nose on.
Ill get ya some better pics later.
here is another i found, Look at the tire and you will find the header.
Kevin
Old May 5, 2007 | 08:40 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
The second pic is of what? Is that your crossmember.
I have an LO3 and wouldnt mind longtubes, how is the power effect with those and do you still have the 700R or is your T56 in?
If I get longtubes will I need a custom y-pipe?
I want to get GMMG's exhaust if I get longtubes. That or dynomax or borla....
What Hedman part # are those long tubes?
And yes. More pictures of the exhaust maybe....with the pop can..or a tape measurer. Thanks and will appreciate more pictures.
P.S. Nice car.
Old May 5, 2007 | 01:16 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Hooker LT's with 1" Hotchkis lowering springs can be seen here..
Pics in post #10 & #13 are at ride height...
https://www.thirdgen.org/forums/exha...er-2210-a.html
Old May 5, 2007 | 01:38 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Nice. But yours does show the Hookers hanging lower than the Hedmans which can barely be seen.
I want to do longtubes but how do I go about having cats and passing a cat test when I do my emissions?
P.S. True duals are the shyt, thats what I'm going for.
Old May 5, 2007 | 01:46 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Should I get my SFC's done before I get a y-pipe made up? I see alot pictures with SFC's installed and the y-pipe tucks to that...
Old May 5, 2007 | 02:29 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
as long as you slow down for the tracks, etc you are fine. the long tubes im not worried about, its the exhaust, the s-bends make the true duals hang about 1/2-1" closer to the ground its raining right now but ill get some pics later if it stops.
Old May 5, 2007 | 02:38 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
This is the setup I will be running.
The Hedman Longtubes 68460 with custom 2.5" Y-Pipe to a Dynatech 2.5" In/Out Cat DTC-79-400250 and to finish the system Flowmaster American Thunder 3" FLO-17234. I like how this Flomaster kit tapers down to 2.5" at the cat so its perfect for my cat since its slip fit or will I need something else for the cat to better match the exhaust.
P.S. Still need to pass Cat Check on Emissions Check ups.
Old May 5, 2007 | 02:50 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
heddman headers, and borla cat back street /strip exhaust! Thats what i have!
Old May 5, 2007 | 02:58 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Borla has been my fav but with a price like they always have I just cant do it anymore. Shyt I wish CORSA would make a 3rd Gen exhaust system....then I'd be buying that no matter what the price. CORSA is the shizznitt!
Shorties or longtubes?
Old May 6, 2007 | 05:28 PM
racer J's Avatar
Engine: 305 TBI
I don't understand the point of wanting long tubes only to snake them down with a y-pipe to a single exhaust system. If you want long tube headers and true dulas, you're going to need two cats and that will run you around $150.00 each for a high flow cat. The cat needs to be a three way with an A.I.R. tube. You would of course need the air tube that runs to your factory cat split off to run to the second cat as well. The cost of the cats goes up as you get smaller and thinner and that's what you will need to have any ground clearance. Duals are one of the more expensive mods if you plan on them tucking tight and passing emissions testing.
Old May 9, 2007 | 09:07 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
stock WS6 springs, with a cut half-coil all around.
Vroooommm! I love this exhaust!
Old May 10, 2007 | 07:44 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Now thats the shyt. Your car is low as hell. But arent Cali roads nice? Lol. Any potholes on YOUR street. Lol. Also that WS6.....OHHHH YEAH!
Old May 10, 2007 | 02:47 PM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Hey ws6Transam I heard your exhaust clip, it sounds really nice. What exhaust set up do you have?
Old May 12, 2007 | 08:21 PM
ws6transam's Avatar
Hooker long tubes to a hand-fabricated Y-pipe, that is then plumbed into a Hooker Aerochamber crossflow cat-back from Thunder Racing. I like it very much, and it's able to handle the power. It's rumbly and understated at idle, but hollers like a NASCAR at wide-open throttle.
Here's what it sounds like when it's on the chassis dyno. 2000 - 6300 RPM, 45 to 123 MPH in fourth gear.
http://www.ws6transam.org/dynorun.wav
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IROCZ1989
Jan 24, 2016 03:55 PM
reiderz iroc
Aug 13, 2015 04:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
