The most ghetto #%$ y-pipe ever made..period
Old May 29, 2007 | 01:07 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
this is my y-pipe Tuffy's auto shop made me for $500 and installed my headers..tried to get my money back or have them fix it but they said they could do nothing...pfft...ya the question i have is..is this y-pipe robbing my hp cuz my car is very slow and i think its really bad..one header is installed normally and the other 1 goes straight down into the other pipe ...bottoms out on speed bumps as u can see below...bent my headers and blew out both gaskets...heats up my oil and makes it boil..braking it down...NEVER go to tuffys....i dont no if u can see it in the pic but if he would have made the pipe a lil longer he could have bent it around the oil pan instead of goin across it....if its not robbing my hp i most likely goin to keep it on there till my 350 is done..I rather put the money into something worth it
Attached Thumbnails The most ghetto #%$ y-pipe ever made..period-imag0066.jpg   The most ghetto #%$ y-pipe ever made..period-imag0070.jpg   The most ghetto #%$ y-pipe ever made..period-imag0072.jpg
Old May 29, 2007 | 01:10 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
Re: The most ghetto #%$ y-pipe ever made..period
that chit is gross..we bottom out on the smallest bump
Old May 29, 2007 | 01:20 PM
xgtharo86x's Avatar
Car: 86' Trans am
the only good side about it it did make my lil 305 sound like a beast from the back lol...dont go to the front now...the exhaust leak is so bad.. heres a clip of wut it sounds like http://www.youtube.com/watch?v=zq52qUMAj2o
Old May 29, 2007 | 02:31 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I feel bad that you paid that much money for your y-pipe (well, not sure how much you really paid since they installed your headers at the same time)
but this is what my custom y-pipe looked like on my 86 Trans Am after they finished it. I paid $197 for the y-pipe, 3" high flow cat, and welding the intermediate pipe to the muffler and to the cat.
And this is how my little 305 sounded afterwards,
http://youtube.com/watch?v=nGTLJ9nS2aI
Old May 29, 2007 | 03:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Hell yes that's robbing horsepower. Could be as much as 50 horsepower. My dad changed that "T" pipe into a true y-pipe on a customer's truck 10 years ago, and it went from 160 RWHP to 210 RWHP, and gas mileage went up 3 MPG, too.
Old May 29, 2007 | 06:53 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
unreal crap!!!!! I would have been wild.
Old May 29, 2007 | 07:03 PM
xgtharo86x's Avatar
Car: 86' Trans am
50hp!!!that would be amazing... i knew something was wrong because i deleted all my emission...junked the cc qjet and swapped a non cc qjet with a elderbrock intake manifold and it has a mild cam...hedman headers and flowmaster 80 series with 3" piping....and it still felt stock or a lil faster
Old May 29, 2007 | 08:39 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Ditto on what Kevin said. The only way the wye could be worse is if the pipe was necked down. You are losing a lot of horsepower. Just a bad job plain an simple.
Old May 29, 2007 | 09:41 PM
Zepher's Avatar
I would print out this thread and show the shop the images of my y-pipe and tell them that is the way it should look.
Old May 29, 2007 | 09:55 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Full 3" Y Pipe from Hooker. The best Y-Pipe I have ever seen. Perfectly tucks under the oil pan and best of all. Came with the headers.
Take a picture of this or Zephers and take that crap to small claims court
Old May 29, 2007 | 10:48 PM
EvilCartman's Avatar
Car: '82 Z28
Here's my old Edelbrock headers and y-pipe. Yours reminds me of the stock 82 exhaust where two small pipes from over the axle T into another pipe that splits off to the mufflers, terrible design.
Old May 30, 2007 | 12:42 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
WOH WOH WOH! Nelapse and others, the pics you posted - is that the stock route of the pipes? If so, someone seriously ****ed mine up! I knew that mine had been redone in a really crappy way before I owned the car, but if thats how it is supposed to be routed, someone didn't know what they were doing.
Old Jun 2, 2007 | 09:17 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
How do you change the oil with that pipe? ... isn't the drain plug right above where they have the pipe routed? ......
Thats easily the most ghetto setup I've ever seen ..... sorry original poster sucks when places rip ya off like that. Maybe you can find a member here with a stock Y-pipe for cheap that you can have adapted cheaply.
Old Jun 2, 2007 | 09:55 AM
xgtharo86x's Avatar
Car: 86' Trans am
the drain plug is on the other side...thats alright everyone gts riped off sometime
Old Jun 2, 2007 | 11:18 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have seen some interesting stuff over the years but that has to be in the top ten.
The best one that I ever saw, and I still to this day 15 years later, was a guy who's exhaust system had rotted out. He took empty beer cans, cut the top & bottom off of them, then split then in half and wraped his entire mid pipe with them. After he was done with the wrapping he wraped it up tight with a coat hanger. It took for ever to cut it all off with the torch. I had stpooed counting after 60 or so cans.
I can only guess that he was on some type of drug binge and must have spent a couple of days doing it.
The things people do.....
Old Jun 2, 2007 | 10:10 PM
87-4MULA's Avatar
Car: 1987 Firebird Formula
wow that is pretty shatty. That is an awful job. I would complain and get my money back. Wow.
Old Jun 2, 2007 | 11:04 PM
geehumshriber's Avatar
Be happy they didn't use PVC pipe and duct tape. I've heard Tuffy's is THEE worst place for most auto parts. I'd go back in and go bezerk, you got jipped on the $500 job. They should redo it for you to keep ANY reputation "up".
Old Jun 3, 2007 | 12:12 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
It look like they took a OEM passenger side part and cut it up to mate to the collector and the rest. IDK why they crossed over where it did....looks farther back than the orig ones. Between the oil pan and the k-member is where my SLP, my old headman, OEM and all others cross at. You can still bottom out with it there if its of a appropriate V8 size, but if you bottomed out that low, youd scrape up more than it. Ive seen ones made for OEM manifolds that are aftermarket. Mac used to make one and someone else I cant remember. What kind of headers are they? Hedman makes an emissions header 1 5/8 primary which is fine for a 305 and a seperate y-pipe that fits nicely . They also have the same header in a non-emissions version but dont list the y-pipe as made for it. But I got the non-emissions headers and the y-pipe back when I had the 305. They worked out perfect together. I didnt get the coated headers, but they were availible. Y-pipe was $89 and jeaders were $95 from Jegs back in '98 or '99. Probably more now. The y-pipe was for their header but a basic 3 bolt flange....2 1/4 flange I think. I could get the part #s if you want them. But $500 for that is rediculous. Hell, my S-10 4.3 was only $200, and its tighter....no aftermarkets are currently availible....and its a beautiful y-merge similar to the one Zephyr has.
Old Jun 3, 2007 | 01:14 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
(I'm sorry, but I just had to do it.)
Old Jun 3, 2007 | 02:26 AM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
Why didnt you just buy the y pipe they make for the headman headers?? I mean I only paid i think like 150 or so for it. Cut out the collector and welded up a 3 inch in its place Ill have some pictures later but thats robbery. I would try and do something about it.
Old Jun 7, 2007 | 10:38 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
what all of you are failing to realize, is that he got a good deal.
i think its the worst y pipe ive ever seen. but, remeber, he had the headers installed.
lets add it 1-2 hours taking old exhaust off. 1 hr putting new ones on (its tuffys remeber lol) 1 hour making the shitty y pipe. plus materials plus good only knows how much time it took those idiots to make the y fit. not to mention those ***holes probably charge 80 - 100 an hour labour. plus all the other charges
he didnt get ripped. just shouldnt of took it there
i got brake pads and an inspection, 600 bucks later and i realized i should of got my friend (liscensed mechanic) to do the inspection for a case of beer, and just put the pads on myself.
lesson learned, shop around. buy tools. work on your own car...
Old Jun 10, 2007 | 12:48 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
That is, without a doubt, the sh!ttiest Y-pipe I have EVER seen..
Old Jun 10, 2007 | 10:44 AM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Mike, why in the world didnt you call me i know i work in a shop. Not to mention i have a very nice y-pipe and i used for like 2 1/2 years and ran 13.2 with it!!!!!! there is no doubt you can get you money back trust me just tell them to cut it off buy mine and we can put it on and go to the exhaust guy i went to if we have to fab anything i all that work wont be as much as what you paid. i one eyed monkey could build a better y-pipe out of bamboo!!!!! if you want to see my y- pipe you got my number just call me its in the back waiting to be sold along with a nice set of headers. Later Daniel
Old Jul 12, 2007 | 12:02 AM
xgtharo86x's Avatar
Car: 86' Trans am
so turned 18 and went down the track before i changed the y-pipe...hit a 15.9@84mph need a new pipe will have 1 soon
Old Jul 12, 2007 | 02:15 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
that is some of the worst exhaust **** i have ever seen. i would throw a brick through their window. teach them a thing or two about "profit margins". make that the most expensive 500$ they ever made.
that reminds me... i got ripped off on a pint job once... where can i find a brick.
for real thoug on the the everyone gets ripped off once. i once paid 200$ for a catalytic converter and the install. i am a dumbass.
Old Jul 12, 2007 | 05:04 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
How about this one?This was in my car when I bought it.Looks like someone wanted to run duals and changed their mind halfway through
Attached Thumbnails The most ghetto #%$ y-pipe ever made..period-100_0216.jpg
Old Jul 12, 2007 | 05:21 PM
AmorgetRS's Avatar
That looks like a system for a 4th gen.
Old Jul 12, 2007 | 06:00 PM
xgtharo86x's Avatar
Car: 86' Trans am
no thanks i need headers to mine are bent from bottoming out.....what y-pipe header kit do you think is good for my car...(some stuff ive done is in the sig)...off summit or jegs i was thinking maybe this 1....id just put a bolt in the o2 sensor hole
http://store.summitracing.com/partde...680+4294840138
Old Jul 12, 2007 | 06:23 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Whoooa here let's think about this first, are you sure your headers are bent? How do you know you didn't just knock something loose so now you have a leak? Also if they are bent are you positive you can't bend them enough to get them to seal again? I had a ghetto Y pipe like that made for my S10, I was ROYALLY pissed when I got the truck back and it was SLOWER than the stock system. I also got shafted on my original Camaro Y pipe, i seriously think it was a bit worse than that one. I ended up swallowing the loss on both of those setups and now I make sure to have the car on the lift and tell them EXACTLY what i want and get a quote right there. That way when I get back I know what i have and I know what I'm paying. If I ever had a job like that done again I'de tell them to redo it or remove it period hands down. Lesson learned the hard way, exhaust shops are generally shady. I have 1 guy in town i trust now and the sad thing is he works at someone elses shop (one of the guys who shafted me on the s10 "Y" pipe). Anyways enough with the ranting life lesson here, my point is check out the headers carefully see if you didn't blow a seal or put a slight correctable bend before trashing them for new ones.
P.S. That looks like 2in pipe on the "Y" pipe, it looks like it goes from 2.5 or 2.25 down to 2 or something, SHODDY!
Old Jul 12, 2007 | 06:40 PM
xgtharo86x's Avatar
Car: 86' Trans am
there deff bent u can see it on the back exhaust ports....everytime i buy gaskets they blowout...plus the headers come to close to the ground anyway i went to 2 other places and they were having problems on where to route it w/o losing power
Old Jul 13, 2007 | 06:51 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
i'm running the flowtech headers that ur looking at and i paid 390$ canadian a bit over priced and primarys are only 1 1/2" but the install was so easy i was amazed took 1 hr get the old **** off then 45-1rh to install the new stuff i didn't notice a huge gain from them but they are for sure alot better than stock and what u have currently , i'm running 14.5 at 95 mph on all stock internals and 80ft of wheel spin
Old Jul 14, 2007 | 12:14 AM
formul8!!'s Avatar
Car: 2004 GTO
That pipe is a POS. I would be embarrassed to let a piece like that go out the shop...
The flat spot, the T junction and the severely necked pipe a killing HP terribly.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
