edelbrock airtube headers?
Old Jun 23, 2007 | 08:22 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
i have a 91 camaro. I put a 350 from an 87 GTA. I have a 91 SD wiring harnesss + cpu in it... if the price is right i may be buying edelbrock airtube headers from a 1992 firebird... will they fit on the 87 motor? and what will i have to change for my exhaust to make them work? do i have to get rid of the 02 sensor also? and are they a decent set of headers? better than stock manifolds im assuming. thanks for your help yes im a newb but am doing all the work myself so im learning fast. i appreciate your help!
Old Jun 25, 2007 | 04:17 AM
tourville's Avatar
Car: 1991 Camaro RS
Re: edelbrock airtube headers?
anyone?
Old Jun 25, 2007 | 07:28 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
yes they will fit ... you need to keep your O2 ... it wil probably have a hole for it
Old Jun 25, 2007 | 07:18 PM
tourville's Avatar
Car: 1991 Camaro RS
thanks =D
Old Jun 25, 2007 | 07:56 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah they are good headers, i hae had them for over 2 years so far, i really like them
Old Jun 26, 2007 | 04:24 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Thats about it right there. You'll be leaving a bit of power on the table using them over say SLP or Hooker shorties.
Old Jun 27, 2007 | 04:20 PM
tourville's Avatar
Car: 1991 Camaro RS
what do you mean leaving a bit of power on the table using them over slp or hooker? will my stock y-pipe work with them? whats the big deal about the air tubes? i see that some people weld em shut? why is that.. here are pics of the Edlebrock TES headers with A.I.R pipes. How much do you think they are worth?
thanks!!
Old Jun 27, 2007 | 05:13 PM
Randy92Z's Avatar
Engine: Miniram 383
Well take a look at the air tubes for example, Ill bet some of them are sticking out into the exhaust flow path inside the primary tube. (mine were) So lets move on down to the collector where all 4 primary tubes are pinched together to get into the 2" opening. Then look at the Y-pipe, you have 2 2 1/4 (cant remember if its 2 1/4 pipes or 2 1/2) pinched at the Y junction to get stuffed into a 3" pipe to get down sized to go into the 2 1/4 stock cat opening. (I think the TPI versions Y-pipes are a little better)
Will they give you better HP and MPG over your stock exhaust manifolds? Absoloutly! But, you are leaving HP on the table for all the reasons I mentiond above.
I now have a set of SLP 1 3/4 shory headers, the primary tubes are not pinched to merge into the collector and the collector opening is 2 1/2 inches. The Y-pipe is a 2 1/2 in pipe and the Y junction is NOT pinched down to fit into a 3" pipe. Same goes for the Hookers as well. Its not a big deal if your not planning on making some bigger HP #'s. But as we all know too well, plans change often.
Hotrodboba400
Dec 10, 2019 07:07 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
