exhaust install
Car: 1983 camaro Z28
Engine: 383 stroker
Axle/Gears: 4:10 full disk posi
exhaust install
im planing on getting a pair of shorty headers soon and i was wondering, do you have to lift the block a little to install them or can you squeze them in there? also what is the best high flow cat to use on these cars or are they basicaly all the same? i would like it to have a good muscle car sound to it.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: exhaust install
ive gotten mine in without lifting the engine, its tight, though mine were
slp 1 3/4 headers. the hoses and stuff will get in the way a bit, but you should be fine.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: exhaust install
I just put my SLP headers back in today. Had them out to clean them up and paint them. I undid the steeringand the master cyl from the brake booster to move it over a bit. Drivers side was a little harder than the passengers but didn't take too long. Then again I have no AC or A.I.R. tubes anywhere so that make life a lot easier.
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
Re: exhaust install
If u have all the factory equipment still on then it can be pain in the @$$....and ive found with these cars that its more difficult on the pass. side
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: exhaust install
My hedman shorties went in without jacking up the engine but I had the factory crap in there so it took me 2-3 days to get the install done. I know a lot of ppl like the CATCO 9118 cat, thats what Im using now and its good.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: exhaust install
draglover,
I have installed mac-performance headers on my car and edelbrock on a friends camaro. On both I had to unbolt the valve covers and got them in place from the top. Im using the 9118 catco with hoocker cat back. It sounds sportier then stock and louder.
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: exhaust install
my hedmans had to have the engine lifted about 3" and the brake lines out of the master cyl. rubs the header. you have to bend it a little. i've had no adverse effects due to bending the brake line a little. And on a side note if i had to do it again i would really get long tubes instead.
Engine: 383 stroker
Re: exhaust install
sweet thanks guys doing it from underneath sounds like it would go in easyer i might try that first and if that dosent work out well i'll figure somthing out haha.
