No Muffler Shop will put an exhaust on my car
1 Post
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I can't find a single muffler shop locally (within 30 miles) who will put a dual exhaust system on my car AND no one will even touch my car if I don't have a catalytic conv on the car. There are no emissions testing required where I live, but they keep saying its a federal law. My engine is not the original factory engine so I though there was a way around this or depending on the vehicles age. Maybe every exhaust shop I've ever been to has done illegal work for me....
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Re: No Muffler Shop will put an exhaust on my car
every shop everywhere does illegal work, the way out is that oh they assumed it was for a track only car, and looked the other way when you drove off with it lol.
they probably dont want to mess around with duals because trying to run them over the axel is really tough and the pipes are pretty much guaranteed to get crushed, they both have to go over the passenger side
best way for duals is turndowns before the axel
Car: 1987 Camaro LT
Engine: V6 2.8 (173)
Transmission: 5spd
Do you have a freind that could help you weld an exhaust on? The place where I got my exhaust done they encourage you to take the cadylac converter off.
1 Post
Car: 1991 Camaro RS
Engine: 355
Car: 1990 Camaro
Engine: 355ci
thats from a thread halfway down the page
hardest part of that setup is installing the headers, thats the system im going to run on my car. I'm gonna throw a gutted cat behind the y-pipe and itll even look like its emissions legal
Car: 1990 Camaro
Engine: 355ci
lol thats jokes, never heard of an exhaust shop turning down business because the guy wants his cat gone
ya should be pretty straight forward man
my buddy told me something about when dumping before the axel the dumps should point in towards the center of the car on a 45 degree angle. Not sure why that is or if theres any truth to it, but might be something to research
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its very common for exhaust shops to turn you away if you arnt legal.
remember your area might not have emmissions INSPECTIONS or emissions TESTING.. but the emissions LAW is federal... and the fine for the shop FAR outweighs the money they can make.
what you can do:
take off the tag.
drive it onto your (aka your friends) trailer.
bring it to the shop.
they do it for your off road only drag car.
trailer it home (or atleast around the corner)
bolt tag back on and enjoy.
what you can do:
take off the tag.
That's EXACTLY what I had to do here in RI. It's the ONLY way I could get the buy to install a straight pipe instead of the CAT. When I set up the appointment the guy said "If it comes in with a cat on it - it has to leave with a cat on it." My Berlinetta had headers installed but nuthin' else at the time so I didn't care if it was on a flat bed !
P.S. my 86 coupe has a factory 2 muffler exhaust on it from an 83 Z28 and both pipes are bent over the axle. What's the big deal with having a muffler shop install the same kind of set-up ???
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
what you can do:
take off the tag.
what you can do:
take off the tag.
it can be done
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
factory dual exhaust huh??? looks like a muffler shop special...
Received 1,676 Likes
The "T" arrangement is factory.
Must be at least 200 lbs of exhaust under that car with all the pics.... that's somewhere around 6-7% of the TOTAL CAR WEIGHT, in exhaust. I wonder what the HP gain vs weight penalty on that turns out to be.
Right, exhaust shops don't want to face fines of tens of thousands of dollars, just so some schmoe can run without a cat. Since cats basically don't cost ANY HP AT ALL these days, I fail to see what's to get all worked up about. Rather like "true duals".... the benefits just aren't there.
Car: 1986 Iroc-Z
It doesnt look factory or beneficial for that matter. I dont see what the point of that exhaust was...
From the 82 Shop Manual:
The "resonator" is the pipe that connects the cat-back to each of the mufflers in the center of the design. In "layman's terms" - The mufflers flow better and sound cool !
A resonator is used on some series exhaust systems. It allows the use of mufflers with less back pressure and provides for optimum tuning characteristics of the exhaust system.
Car: 91 Camaro Vert
it sounds cool
it looks like a muffler shop hackjob, but yes, that was OEM in 82... i know. i had one.
go look at a model car for that year.. they have the same muffler thing too.
and it does sound good... flows like crap, but this was in 1982.. hell the motor bearly made 100hp.. LOL.
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Why don't you just have them incorporate your stock cat in the setup, then when you get home you can either gut the cat or install a straight pipe.
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
i think some people don't put in the cat because it costs more than they can afford.
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea they can be ***** [Please watch your language]......a few options, take the tag off and trailer it to the shop, tell them its a race car only and has no registration if they hessitate tell them, if they desire do it under the table with no paper trail............ go to your local track and ask people there alot of the guys have the crap at their home shop to do it, toss them a case of beer and some $20's............ hollow out a cat and bolt it up, it looks like a cat it must be one LOL...... good luck
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
emissions work is a touchy subject. if they remove emissions equipment i believe it is a $10,000-$25,000 fine depending on conditions. some people know they won't get caught easily, others though don't want to take that much of a risk and I can't blame them. plus being this is a federal law it doesn't matter if you have emissions testing in your area or not. that is state run on if they enforce the testing part but still the federal law says you must retain all original equipment or equiv replacement at all times. the feds will enforce that one not your state. it's just like marijuana in california. sure for medical use it's legal as far as the state sees it but if any fed government agency sees you with that stuff growing or in your controll your going to jail.
best thing you can do is either do the work yourself or as others have said trailer it in without tags and make it look like a race car rather then a street car.
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
you don't live in north east GA do you? cause im from GA too and i had the same problem getting duals put on my mud truck........no tag no bumper....40" tires and they said " cant do it" " you might decide to register that thing"
My personal advice........have the cat put in.....take it home get out the sawz all and trash that POS
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Cats are good. They keep the guy behind you from passing out.
-- Joe
-- Joe
These same people that can't "afford" to make their cars LEGAL, seem to have plenty of money for various idiotic non-functional "bling" (not that in this specific case, this specific poster is necessarily one of those, but in general).... stupid chrome crap under the hood, wheels that don't fit and/or look ugly and/or mismatch the car, stereo equipment, and on and on and on.... yet when it comes to something where you come to the fork in the road, and if you take one path (cat) you get to drive your car, but if you take the other path (no cat) you CAN'T drive your car... they "can't afford it"?
What a CROCK!!!!
Cats are CHEEEP. The LAW is the LAW, and it applies to both YOU and to the BUSINESSES that have to still be in business tomorrow if they want to continue to EAT, and some kid that wants a loud car and thinks that just because he hacked a non-original motor into it, isn't worth risking their LIVELIHOOD over.
Here's a typical cat for our cars. http://store.summitracing.com/partde...rt=WLK%2D15043 If this is SO MUCH MONEY that you "can't afford it", then maybe this isn't the right hobby?
Car: 1991 Camaro B4C
Engine: L98 350 cid (5.7L) TPI v8
Transmission: 700 R4 auto trans
Axle/Gears: 10 bolt w/girdle & 3.42 MotiveGears
It's just funny how life goes.
I live in a non smog state.
I took mine to several local shops.
Everyone said they would replace them
with new ones, but not remove them.
I went to a high performace shop.
He said the same thing.
Other than that he was the most cooperative, so
I had him do the install of the headers, dual cats & cat back.
Less than a month later my neighbor took his 1998 Mustang GT
to the same High pro shop & they took all his cats out, installed his
headers & a different style "x" pipe along with some other go fast
goodies without any problem.
Go figure.
He must have liked working on Mustangs more.
Go figure.
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
BUY A CAT. stop screwing around. people that do this give our hobby a bad rep. i bought a catco 3" cat for my 89 RS 305. lets just say it was the LEAST expensive part of my exhaust system, i think it was 125 bucks. the headers were 500 bucks and the cat back was 250 bucks. get a good flowing cat. newer technology used in more modern cats it much better than they were when your car was new, you loose very little if any horsepower by doing installing one. protect the environment and yourself by installing a cat. when i did my exhaust i made everything fit and operate as it did when the car was new. smog pump, emissions compliant headers with smog tubes. i know that my car is putting out as little hydro-carbons as possible. not to mention it is very easy to get it past inspection with everything hooked up and operating as intended. the inspector can say nothing about it at all. i even have the edlebrock emissions legal decal mounted on the cooling shroud. just because your state doesn't have any emissions inspection now doesn't mean they wont in the future. i might pass new laws and then your 1000 dollar exhaust system becomes glorified scrap metal.
1 Post
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
But that is within a "smog" country. Your state has just chosen not to profit by inspecting emission controls. The fine is the same there as anywhere. The shop is probably picky about who they break the law for and you didn't make the grade. :-(
I fired a tech at our shop for gutting converters for "friends". If we had been busted, it would have closed us down.
I have 4 camaro's right now, every one has a gutted cat., well My Berlinetta has a straight pipe as explained earlier.
The state inspection is due on one of them and I will go out - buy the direct fit cat, install it, Pass the test, then remove it and sell it to a board member.
There's a lot of reasons, Like the smell of a hot car after a "workout", The "tone" of the exhaust, No more Hassles, & Because that's how I like it.
Make it a PRIVATE party and don't expect a mechanic that turns wrenches for a living to do you the favor !
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
These guys are 100% right, it is a federal law, and is randomly enforced by federal agents with very tight underwear, when and where they decide to. They send in young guys like you to "bait" the shop into doing something illegal, then WHAMMO!!! A motorcycle shop around the corner got nailed for a $40,000 fine because they SOLD a used bike that was missing it's emissions equipment. They've been selling bikes like that for 20 years, and NO state tests Motorcycles for emissions, so I thought nobody cared. It's just and example, the proprietor has a lot to loose unless they KNOW YOU PERSONALLY. This is your federal government looking out for you...
...besides, also correct is unless you have a SUPER NASTY ENGINE, you won't loose any power by running a high-flow cat. They'll put one on for you, but you have to show up without one or with a dead one, removing a functioning cat is also illegal. (Sigh...)
TA
TA
TA
TA
remembered my good buddies exhaust shop, called him up, he said not a problem, cause he knows me... they replaced my rattling cats with a 3" pipe for now, till i do my complete exhaust... just for 30$
my suv runs stronger, more bottom and top also, and alot quieter without the rattle, and my lope is alot more noticeable after the stock exhaust muffler...
im going to run without cats from now, just get the LTs, and a good muffler..
Why don't you just buy an off-road cat? It's like a straight pipe but with a cat on it. A gutted cat just creates a harmonics disruption problem.
Car: numerous
Engine: ls1, others
That's about the LAMEST excuse that could possibly exist.
What a CROCK!!!!
What a CROCK!!!!
and about the hobby; i am not building a drag or track car so it's not even a hobby due to lack of money
1 Post
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
If you live in NE Ohio area I know place that put 2 1/4 dual (all my 305 needed) true duals on your car for about 200 bucks! a tiny bit more for 2.5-3" PM if you need it it's in Steubenville OH, Wierton WV area. and as according to the law, you have to promise me you are not a cop or apart of some pollution **** group so i don't get these cool dudes in trouble. it's cheap fast and it sounds awesome!!
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Axle/Gears: 2.73/stoke/soon to be 3.47
Where I live in mass there are a couple of import performace places that are glad to do that work IF you buy the things you need from there shop and they only charge you 100 dollers to instal the stuff and when you go for a sticker they will put your stock stuff back on and when your done they will put stuff back on for FREE...
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
I find it very odd that you can't get a dual, though. As long as you do include at least one cat where all of the exhaust goes through it, there's nothing wrong with that. ( except in The Peoples Republic of California ) (( unless, of course, you tried arguing with them, and P'd them O )
If it has no cat now, but it should, there should be no problem putting at least one back in.
Furthermore, there is NO disadvantage to a cat today. None ! Hollowing out, or removing a properly sized modern honeycomb cat is both illegal, and a complete waste of time and effort.
How do I know ? Have I actually measured flow and backpressure both ways ? Well, yes I have !
My vehicle is hardly stock, and there's no problem passing emissions testing here ( Ohio ) with TRUE 3 inch duals. ALL duals, including dual 3 inch cats. ( $65 each at AutoZone, and garaunteed for life to boot ! )
Yes, there is a way around it depending on the vehicle's age.
If ( but only if ) it's old enough to have never had a cat from the factory, and in some locals if it's plated as a historic or antique vehicle, not a daily driver.
Your only other alternative, is to buy all the pieces parts and do it yourself.
Car: 81 Chevy 4x4/86 T/A
Engine: 5.7L/5.0 (both modded)
Transmission: TH350/700R4
Axle/Gears: stock
My 86 T/A has an apointment on tuesday for a new exaust system.. At first i got a price quote for true duals and it was about 400 with high flow cats and i couldnt afford that so i got one for a factory style header back one and it was 190ish with a high flow cat (me providing the flowmaster and tips)... The only reason im not getting duals is after building the engine bolting up some edelbrock shorty headers and dropping it in my savings account is nearing zero so im getting the single to dual till i get some more money...
I can understand them not wanting to do it without putting cats on but not doing it at all? Unless they just order the systems and then install them and dont actually make custom exausts....
Like some other people said why not run cats?
Im in indiana and they dont smog test here but if they are a business getting paid to do the exaust it has to have a cat due to federal law
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
You can't find an exhaust shop to do your setup in Indiana? I bet it's not because of the cat more because you want the duals ran. I know a few other people who were trying to get duals with no cats and that excuse seemed to come up more often than not. When they said "how about a 3in single and I don't need a receipt" the shops were more than happy to oblige them. It's pretty ridiculous I've seen the excuse "we can't do it without a cat" come up at muffler shops but in the next bay they would be running 2in duals manifolds back on a full size trucks with no issues.
Car: 1986 Iroc-Z
Most places pick and choose who they will do that kind of work for. My exhaust guy had no problem with my car when I brought it in with no cat, just a Y pipe. I did however already have most of the exhaust so he didnt have to fab a bunch of pipes up. But depending on the state you live in and what kind of muffler shop you goto you should be able to get the work done. I would try the local shops in the area, not the chain shops. Hell you could even get by drivin around with open headers.
Car: 87 GTA
My wife was the Supervisor, for Texas DPS, in the division that checked out inspection stations, and made sure they were doing everything, by the book. No cat deletions, no cat gutting, etc. They would routinely send cars into stations, with KNOWN violations. They would even make the mos themselves, and see if the station would "look the other way". If the car passed, the station was busted.
The fine for messing with emissions equipment, including possibly being shut down, was WAY too high, for stations to try to skirt a Federal and state law.
#42
That's the fact in a nutshell right there.
#43
Run your car on showcar insurance. Cheap, though limited mileage.
Dont' have to have anything on my car emissions wise as being a "show" car it is limited in the mileage I can drive it.
Insurance company never asked for how many miles were on the car when I switched to the show car insurance, and it hasn't had an emissions inspection since its waived with the show car insurance so there is no mileage reported.
I pay about $11/month for about $9000 in coverage on my GTA. Even though its far from a show car I told them I was showing it in the stock class but don't drive it all that much, which is true. I bought it on Sept 11th 2001 with 98,000 on the clock, and have only have 105,000 miles on it now. So I put about 1,000mi/yr on the car per year average. Well under the 3000 miles per year I'm allowed.
#44
Car: 84 z28
Engine: 355
Transmission: TH350
OK, where me and the thread starter live, in GA, there is no emissions check B.S, and all of the GSP a holes are to lazy to crawl under a car to check for it...as a matter of fact i had a buddy in high school with a 65 chevy pickup that had Striaght hedders(no pipes after headers) who ran around for like a year like that...The only time, i repeat, the only time you can get into emissions trouble around here is when you hoss you moter to the wrong cop.
AND ANOTHER MATTER......What about the guy with the straight piped diesel pickup blowing a humoungus cloud of black smoke in the air? I believe thats a bigger deal than a lil bit of smoke of a v8 car
#45
Car: 87 GTA
People automatically assume, that the black diesel smoke is bad, even I used to, until I learned the truth.
#46
Car: 84 z28
Engine: 355
Transmission: TH350
i honestly could care less about diesel smoke....it makes my living everyday
#47
Location: Great Smoky Mountains, Bryson City North Carolina
1 Post
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
The picture of the funny looking dual pipes on the 82 is factory. Some of the earily 83's had them also. The 65 Chevy truck mentioned does not have to have cats, because it did not come with them originally.In Georgia, the emissions have to appear stock. If the shop modifies the car from it's original form, they can be fined. Federal law. If your car came with a cat, it has to have one to be legal, but you can run cats and no mufflers. I have done it, and it sounds pretty cool. The best part is it's still legal!
#48
Car: 1990 Camaro
Engine: 355ci
wow i havent seen someone actually make that setup work before.
With stock suspension componenets like on my car im pretty certain theres not enough room to run it through, the tubular stuff looks like it gives you a bit of extra clearance.
very nice
very nice
#49
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
#50
Guest
Posts: n/a
The truth? Thats not the truth. The truth of the matter is photochemical smog requires particulates to form. While removing all particulates from diesel engines wont remove the particulates required to form smog, it will reduce the amount available to carry out the process. Thats not to mention the sulfur, even in the low sulfur fuels, that falls to the ground, and enters the water supply and I'm totally ignoring the airborne problems of it.
