full headers or shorty headers?
Old Sep 3, 2007 | 08:24 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
im planning on getting some headers for my 350 engine build.
i just need to know which are better to get. shorty or full headers? and is there any difference in preformance between them?
i would like to have true duel exhaust so im just woundering what are easyer to work with?
full ones or the shorty ones?
Old Sep 4, 2007 | 12:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: full headers or shorty headers?
How important to you is ground clearance?
Old Sep 4, 2007 | 12:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
true dual exhaust is better with long tubes. I have a post of mine and a few videos in this section. My camaro has 4-5" of ground clearance and I have never bottomed out the exhaust on the street, but I never have gone over a curb, or speed bump in the road with this car. The only time it rubs is when I go up and down the trailer, the s-bends just lightly touch the trailer's dovetail.
Old Sep 4, 2007 | 12:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
True duals are better with long tubes, but you don't need true duals, and the loss of ground clearance might make it not worthwhile.
Old Sep 4, 2007 | 01:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Oh sorry I thought his mind was already made up on true duals, just he wanted to ask about shorties or long tubes being easier. Well in that case, then yes a single 3" catback is good enough with shorties for 85% of the people on this site for their power levels and ground clearance will be fine. Mine are just tucked in a manner that ground clearance is more than acceptable to me.
Old Sep 4, 2007 | 07:21 PM
joshh44's Avatar
Engine: engineless
oh ok.
do they make medium headers? lol
not quite full and not quite short eather? kinda inbetween?
my ground clearence is not to bad.
i lowered my car so it does like to run on the high speed bumbs. thats about it. depends on how fast yoru going over the speed bumbs as well.
(i take my time with my car going over them bloody bumps lol)
how much was your exhaust done with the true duels from the long headers?
i was thinking maybe having the exhast exit just before the rear axle?
i havnt quite made my mind up on that.
i just put on some cheap crap cherry bomb turbo muffler(PURE CRAP!!)
it was cheap and i needed an exaaust on my car. cost me $280 to get new exhaust pipe from the Cat. back to the rear. and its only a single outlet to
if its going to cost me huge dollars i might just get the shorties and get a y pipe and stuff.
dont seem to be to to bad.
what do you guys think?
Old Sep 4, 2007 | 07:40 PM
subliminal's Avatar
Hawks thirdgen makes a set of stainless steel long tube headers that are supposed to have good clearance. Theyre not cheap though.
Old Sep 4, 2007 | 07:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you put long tubes on a lowered car, you pretty much won't be able to take any speed bumps. I wouldn't bother with duals, just run shorty headers with a decently sized single exhaust. You'll keep your ground clearance, and you won't be able to tell the difference in sound or performance.
Old Sep 4, 2007 | 11:08 PM
joshh44's Avatar
Engine: engineless
sounds like i may have to get some shortys.
i do tho like the looks of the full ones.
maybe one day ill get full ones.
would a 3inch exhaust be a good size.
i hear 2 and a half are alright.
i got 2 and a quarter right now.
and what is a good muffler to get for a nice thoaty kind of sound?
something sounds mean!
Old Sep 5, 2007 | 11:43 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
for a 350 for 3".....depending on how much power ( and money you're looking to spend), you might want to go 3.5. DO NOT GO 2.5"!! I learned the hard way and the 2.5" is killing my power right now....then again I have a 383. 3" exhaust and pick what brand you want depending on what sound you want. I myself am going with the magnaflow. I also like the sound of the Hooker Areochamber exhaust. Look in the sticky or search for exhaust sound clips.
Old Sep 5, 2007 | 08:42 PM
joshh44's Avatar
Engine: engineless
oh ok thanks a bundle
ill go check out them sound clips
by the way.
do exhaust leaks reduce HP?
Old Sep 13, 2007 | 12:40 PM
Car: 92 Camaro
Axle/Gears: S60 373
yes...think of it as a straw.....and u cut the straw and make a small nic in it and u cant flow as much as before...
Old Sep 13, 2007 | 12:43 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if you still have the same open end on the straw and then add another little nick you should be able to blow more air through it and have it easier to boot.
as far as horsepower though.... eh kinda depends on a few things though I guess.
Old Sep 13, 2007 | 01:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Exhaust leaks are just annoying, they don't reduce power.
Old Sep 13, 2007 | 07:41 PM
joshh44's Avatar
Engine: engineless
yes they are annoying.
thanks for the info tho
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
92projectcamaro
Jan 18, 2016 08:00 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
