Where is o2 sensor
Old Sep 7, 2007 | 09:06 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
Where is o2 sensor
1985 Firebird -
Where is the o2 sensor on this damn thing?? I'ved been searching for an hour trying to find it. I know its before the cat and in the manifold somewhere, but i just cannot find it. Help?
Old Sep 9, 2007 | 12:04 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Re: Where is o2 sensor
I've got a 86 V6, so thats what I'm going from...
Find where the two pipes from the manifolds meet (your Y-pipe) and go towards the cat like a foot-ish from the weld. Mine is on the left side of the pipe if you're looking from the cat.
Old Sep 9, 2007 | 09:44 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
Yeah I found it. (or should I say I didn't) No wonder I'm getting a check engine light for 02 sensor. There isn't one. There is a big weld spot right where the o2 sensor should be, and the connector piece for the o2 sensor is right above it. Looks like I'm going to need a new exhaust. Oh well, I needed one anyways.
Thanks for the reply,
Jake
Old Sep 10, 2007 | 10:22 AM
Car: 86 Firebird
Engine: 2.8 V6
Hah. Yeah...that would make it hard to find.
WOH WOH WOH! You don't think you need a new exhaust because there isn't an O2 sensor there, do you? You can pick up a basic one for like $30. It screws in, doesn't need to be welded. The weld you see is just a bung to screw it in to.
Old Sep 10, 2007 | 10:37 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Someone may have welded shut the O2 bung, that's what it sounds like. Then he will need a new exhaust.
Old Sep 10, 2007 | 03:56 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
Yeah, someone welded it shut. Plus, the current muffler and cat and in fact the entire exhaust piping is hung by pieces of chicken wire. Plus has hundreds of holes and is almost rusting through in some spots.I got a good deal on the car though, so alls good. Yep, that exhaust needs to be changed. How much better gas mileage do you think I'll be able to pull off with straight pipes and that o2 sensor? I pull off 21 right now, and I have cat on it (Which I'm sure is blocking airflow, it rattles when I move it)
Old Sep 10, 2007 | 04:05 PM
Car: 2000 BMW M5
#1, a muffler will not hurt the power output of the wimpy V6
#2, no one wants to hear a blasting loud 2.8 trying to make it up a hill, use a muffler!!!!!
Old Sep 10, 2007 | 04:08 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
hehehe...
Old Sep 10, 2007 | 04:10 PM
Car: 2000 BMW M5
LOL it is true, my 83 now-V8 trans am originally had a 2.8 in it, back when my friend owned the car. With a cherry bomb on it, it sounded like a dying cow as it struggled to go up hills, as handicap vans passed on the left.
Old Sep 10, 2007 | 04:34 PM
Soenneker's Avatar
Car: 85 Firebird
Engine: V6 2.8L
Heh. But how much better gas mileage would it get if I had an oxygen sensor?
Old Sep 10, 2007 | 05:24 PM
Car: 2000 BMW M5
Depends on how rich the open loop tune on that engine is at operating temp, vs. the closed loop tune. You will probably get at least a few mpg better w/ the O2. No guarantees though.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
