best shortie headers
Old Sep 9, 2007 | 01:39 AM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
Right now I have heddman shorties and the small 2.5" y pipe it came with.
Is there a better set of shorties I can buy that have a 3" y pipe?
Old Sep 9, 2007 | 11:40 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: best shortie headers
do you mean 3" outlet size or a 3" pipe going from one side to the other?
as far as i know, a shorty setup with a 3" pipe going from the driver-side and connecting to the passenger-side does not exist, and i dont think the 3" pipe would fit in the stock location anyway.
as far as 3" outlet size there are may different ones, i know edelbrock has them, SLP has them as well, though the y-pipe is a dual 2.25" that merges into a 3". hooker, and most likely headman as well as others
Old Sep 9, 2007 | 12:21 PM
Car: 1986 firebird
thats what mine does it goes from 2.5" to 3inches.
I was seeing if there was a y-pipe that was all 3inches but ive been looking and no one makes them. Guess Im stuck with what I got.
Are the hooker shorties better then my heddmans? I dont need any emission as of right now i have no cat.
Old Sep 9, 2007 | 02:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the only differences are maybe quality, usually headman has 5/16 header flanges, hooker usually has 3/8, bla bla bla.
You would probably not be able to notice the slightest performance differente between the two. Only other way to go it longtubes
Old Sep 9, 2007 | 04:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A 3" dual y-pipe wont fit under the car. My dad has a 2 3/4" dual y-pipe setup under his car, non-lowered, and it just barely fits.
Old Sep 9, 2007 | 07:28 PM
Car: 1986 firebird
thanks for the info 86
Guess im using what I got for now, until I can get longtubes and some free time to install them.
Old Sep 10, 2007 | 01:46 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
dont bother with SLP, they have discontinued all headers and exhaust systems for our cars
Old Oct 7, 2007 | 10:54 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I just bought a set of SLP shorties and Y pipe used off another member. So look around, you can still find them.
Old Oct 10, 2007 | 02:29 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
slp shorty 1 3/4 headers are the ones to keep an eye out for. However, they do not make them for our cars anymore. I have a set of Edelbrock 1 5/8 on my car and they are not bad. Right now since I have a 383 and wanting to opening up the exhaust, I am toying with the idea of LT and maybe trual duals.
Old Oct 10, 2007 | 06:39 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
IMHO Dyno Don makes the best 1 3/4" shorty header on the market. Raised exhaust port so there are no restrictions. A full 2 1/2 inch on the collector.
Again I have not been impressed with the Edelbrock headers. Saw a set today that had 1 1/2" on the outside cylinders and 1 5/8" pipes on the inside.
Old Oct 12, 2007 | 03:20 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Again I have not been impressed with the Edelbrock headers. Saw a set today that had 1 1/2" on the outside cylinders and 1 5/8" pipes on the inside.[/quote]
OK, OK, but they're not on my car anymore..
Bill
Old Oct 12, 2007 | 04:32 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
i have hooker shorties, and 3" pipe all the way back, with no issues
Old Oct 14, 2007 | 01:06 AM
Kevin91Z's Avatar
The question is about a dual 3" y-pipe, not a 3" intermediate pipe.
Old Oct 15, 2007 | 09:35 AM
Axle/Gears: 4.10
my appoligies, i miss read
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Night rider327
Sep 16, 2015 02:20 AM
