exhaust glowing
Old Oct 1, 2007 | 12:17 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
exhaust glowing
what causes this? at say under a load muffler and intermediate pipe start glowing. from the cat forward nothing.
Old Oct 1, 2007 | 02:08 AM
blackbird615's Avatar
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
Re: exhaust glowing
from the cat forward, being from the cat towards the front of the car? my best guess would be your car running extremely rich with a clogged cat, but because you say it's after the cat, i'm baffled... it could still have something to do with your car possibly running rich.
Old Oct 1, 2007 | 03:08 AM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Re: exhaust glowing
I'd say that your car is running rich and the cat is NOT plugged. The cat burns raw fuel so all that heat goes into the intermediate pipe and muffler. If the cat is plugged then it will start glowing too since the heat is being trapped inside. But if you run the car long enough the cat WILL start to glow. If it continues to do this the cat will self destruct and WILL get clogged and need replacement. Unfortunately the convertors dont take much excessive heat to destroy them. You will probably need a new cat soon. Better find the cause of the rich condition first or youll burn up another cat.
Old Oct 5, 2007 | 12:15 PM
83Formula's Avatar
Re: exhaust glowing
when my cat was full it and the pipe started glowing and then started burning the carpet in the car under the passenger seat.
gta892000
Aug 11, 2019 11:16 AM
zapr
Jul 27, 2018 06:03 PM
86White_T/A305
Mar 6, 2016 01:48 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
andy74
Sep 3, 2015 08:41 AM
