AIR !, need to plug the holes
Old Oct 7, 2007 | 02:30 PM
ajk511's Avatar
Car: 1991 z28
I just removed my air system, but im not going to be able to put my headers on for another week or so. I just left the AIR tubes coming off the exhaust manifolds, but im getting wicked backfire from leaving them open. Anyone have any ideas for plugging up those two gigantic holes?
Old Oct 7, 2007 | 04:51 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: AIR !, need to plug the holes
I just collapsed the smaller tubes, easy fix, mine just broke, never backfired tho, only let exhaust into the passenger area
Old Oct 7, 2007 | 06:01 PM
ajk511's Avatar
Car: 1991 z28
what did you use to collapse the tubes? i tried this giant crimper but i couldnt get them to collapse. for now i just cut a small piece of the rubber tubing from it and super glued the cap from a quart of oil over the hose. should be ok to get me from my house to the shop next week.
Old Oct 7, 2007 | 08:35 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
He's talking about crimping the smaller pipes after they split for each cylinder. If you don't want to cut everything up, you can do what I did on my winter beater. Go to the plumping section in your local hardware store and buy a couple of metal pipe caps. I think the threading is different but they'll still seal. I don't remember the size, but measuring the AIR pipes will get you close enough.
Old Oct 7, 2007 | 10:24 PM
ajk511's Avatar
Car: 1991 z28
sweet thanx guys.
Old Oct 8, 2007 | 07:14 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
1/4 n.p.t. , any hardware store will have plugs .
Old Oct 8, 2007 | 12:59 PM
ajk511's Avatar
Car: 1991 z28
thanx for the sizing Tom. im going to go pick up some plugs right now.
Old Oct 8, 2007 | 03:27 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
They are actually 5/16 flair plugs in the manifods and I believe you can unscrew the valves on the AIR tubes and put a pipe cap over it. It is either 1/2 npt or 3/4 npt.
Old Oct 8, 2007 | 04:58 PM
TheBigJ's Avatar
Car: 85 Firebird
Bingo
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
BurlyChev
Aug 22, 2015 01:52 PM
