will this dual exhuast setup work????
Old Nov 3, 2007 | 12:25 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i was wondering would this dual setup work for my 88 gta.... its two 2.25 inch pipes using the stock route of the original single system.....could this work... i have hedman long tubes and this should fit and ground clearance shouldnt be a problem because its the stock route..... do you guys think it will sound better than a 80 series setup.....
http://a592.ac-images.myspacecdn.com...30938caf67.jpg
http://a840.ac-images.myspacecdn.com...28785fa4cf.jpg
Old Nov 3, 2007 | 12:49 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: will this dual exhuast setup work????
i've seen a few setups that run pipes in the stock location and up over the axle. ground clearance was like stock if the pipes are fabbed up right. what you ahve pictured does look promising as long as they run near stock location. 2.25 isnt a huge pipe so clearance will be ok. you'll be able to fit that over the axle no problem
Old Nov 3, 2007 | 08:29 AM
88fastgta's Avatar
ok thanks..... would that setup sound better than the crossflow 80 series setup... cause im planning on putting two super 44 mufflers on there with hedman longtubes....
Old Nov 3, 2007 | 10:09 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
wont be loud, at all
Old Nov 3, 2007 | 02:43 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
2.25" I wouldn't waste my time with that you would be better off with a single 3" as for performance, not to mention the weight factor and ease of installation.. my .02
Old Nov 3, 2007 | 03:09 PM
88fastgta's Avatar
i meant to say 2.5 inch.... but wouldnt that setup sound better than a 3 inch 80 series setup.......
Old Nov 3, 2007 | 05:59 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
The 2.5 would definitely sound better imho over the single 3...
Old Nov 3, 2007 | 06:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
my buddies car has a 408ci motor in his thirdgen. has 3inch flowmaster 80 series. quieter than my bolt on L98 and even doesnt sound as mean as my car at idle, they sound bout the same. his car does sound good just not all that loud but it aint quiet either. my car screams pretty good.
i used to have 80 series and his car sounds better than my did with 80 series and a cat
Old Nov 4, 2007 | 09:27 AM
wannafbody's Avatar
Car: 88 GTA
so what do you have now?
Old Nov 4, 2007 | 10:59 AM
JustA305's Avatar
Car: 92 Convertible 25th Anniversary z28
Engine: Tune Port Injected 305
Transmission: 700R4 with 2200 stall
Axle/Gears: 3:42 with new posi unit
I have a 92 z28 with hooker long tubes ran about the same way your talking about having yours ran, dual 2.5" but I have a x-pipe right before my dual magnaflows dumped right before the rear end instead of running it out the back. I love the way magnaflows sound and the x-pipe gives it a good sound too. Plus being dumped it is really really deep and in my opinion magnaflows are the only way to go. After having magnaflows on this z28 and having them on a 68 c-10 I had I wont ever run anything other than magnaflows.
Old Nov 4, 2007 | 11:46 AM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
I run 2.5 but not in the stock location with an X-pipe into dynomax super turbo's dumped and I get alot of complements...I'll post up a sound clip when I get a chance in anybody is interested...
Old Nov 4, 2007 | 11:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i have 3inch single setup using the old flowmaster pipes but a custom fabbed rear over the axle section to retain dual outlets like the flowmaster did. 3inch all the way out to 3.5inch tips. for a muffler i mounted a powerstick chambered tube in the I-pipe area behind the cat. 20inch long. gutted the cat now. clips in sig
Old Nov 4, 2007 | 01:24 PM
Demon355's Avatar
Compression does wonders
I have Hooker shorties, custom 3" ypipe, 3" cat, 3" ipipe with a Bullet muffler in it and it dumps over the axle for now. It's decently loud but I want to get 4thgen tips. Would the sound change at all? Maybe louder?
Old Nov 4, 2007 | 06:04 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that's greezemonkey's old setup, it's for the hooker bbc swap headers. it won't work on your hedman longtubed sbc without major modification...and ground clearance WILL suffer.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
onefreakz
May 14, 2018 12:15 PM
Street Lethal
Aug 13, 2015 08:28 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
