hedder/muffler recommendation for true duals.
Old Nov 13, 2007 | 08:52 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I want to do LTs to dual 2.5" pipes into flowmaster super 40 mufflers, my question is which brand of hedders(LTs) will fit my '86 camaro without hacking or grinding too much? if I can find a good fitting 1 3/4 i'll go that route but if not i'll stick to 1 5/8. I know a lot of you guys are running around with LTs and true duals out there so share the knowlegde and your experiences.
Old Nov 14, 2007 | 08:00 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: hedder/muffler recommendation for true duals.
I have hedman lt hedders 1 5/8 out to moroso spiral mufflers and then they dump on both sides before the rear tire. I believe any header will need some twiking to get it in the engine bay. I have to do a little bending on the frame to get mine to work without rubbing.
Attached Thumbnails hedder/muffler recommendation for true duals.-101_2506.jpg   hedder/muffler recommendation for true duals.-101_2430.jpg
Old Nov 14, 2007 | 11:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by leeperryracing
I want to do LTs ...
Not legal in Denver.
Old Nov 14, 2007 | 11:21 AM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
what are LT's? and you can run headers with the A.I.R. tubes in it and that would be legal.
Old Nov 14, 2007 | 11:27 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Lt= long tube headers. And yes you can purchase headers with AIR tubes or buy headers with out them and then get AIR tubes and weld them on. And check your towns emissions requirements and see whats legal and whats not.
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
[quote=ryan91rs;3532356]what are LT's? its short for long tubes
Old Nov 14, 2007 | 01:12 PM
five7kid's Avatar
Originally Posted by 84 z28
... you can purchase headers with AIR tubes or buy headers with out them and then get AIR tubes and weld them on...
Nobody I'm aware of offers long tube headers with A.I.R. tubes. Welding them on is an option, but you're still stuck with needing to locate the cats in the factory location - not an easy task with long tubes, nor an efficient one.
You'll also need an O2 sensor, because any 3rd gen that's emissions legal in Denver will have to have a feedback induction system.
Old Nov 14, 2007 | 01:25 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I'm using hooker super comps and dual bullet mufflers
Old Nov 15, 2007 | 06:14 PM
five7, my car is registered in eagle county so I have no worries with the emissions money making crap...all they do is mail me my tags every year for a grand total of $26. For the past three years i've been running edelbrock hedders(air tubes cut off and welded shut) into 3" y-pipe, cut-out at the end of y-pipe, no cat and into 3" flowmaster american thunder exhaust. I just started using nitrous this past season and thought a more "efficient" exhaust system would compliment the motor.
P.S- im using an innovate LM-1 system for O2 sensor duties, i don't even have an ecm in my car
Old Nov 15, 2007 | 06:21 PM
scorchmaster could you tell me the part# for your hooker super comp longtubes? and 84 z28 could you do the same with your hedman longtubes and which of these hedders are a better fit? thanks for the input guys, i appreciate it. Any gripes or likes for the flowmaster super 40 mufflers?
Old Nov 15, 2007 | 06:36 PM
five7kid's Avatar
The p/n's for both are in the header stickies.
Old Nov 15, 2007 | 06:39 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I have PN#68468 and there thermal coated. I would aslo get the hedman s extensions so the exhaust clears the tranny crossmemeber.http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...0&autoview=sku
Old Nov 16, 2007 | 06:34 PM
thanks a lot 84 z28, how is the fitment with those hedmans? were they easy enough to install or did you run into some issues? let me know because I like the price on them
Old Nov 18, 2007 | 09:08 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
The fitment was ok I have to dent the frame on both sides to get the headers to fit perfectly but every car is different. And plus I coundlnt see denting my brand new headers. overall the install was easy and they work very well.
Old Nov 19, 2007 | 09:15 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Damn I was thinking about getting some hooker 2210s cos I thought they were the only option they are like 430 painted and like 730 ceramic coated. Well I saw these heddmans on jegs https://www.jegs.com/webapp/wcs/stor...0002_316394_-1
for like 380 and they are thermal coated with like a chrome finish.. I think its clear which one im getting now.
Any fittment issues on the heddmans??? Where does the o2 sensor go??
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
