X pipe? anybody make them
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I have been looking into this and I can't find anyone that makes them. whats up with this?
Axle/Gears: G92
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: X pipe? anybody make them
are you looking for just a universal x-pipe, or one that will fit a thirdgen? cause you can find the latter
Axle/Gears: G92
Car: 1987 Iroc-z Convertible
http://store.summitracing.com/egnsea...=KeywordSearch
all of them will require fab work because none of our cars came with one. this one is 3" they also have 2.5"
Car: 86 Trans Am
just keep in mine, 3rd gen cars did not come with dual exhaust, so to have dual exhaust and use the x-pipe would be a total custom job
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
The reason there isn't an X-pipe for a third gen is the fact that all 3rd gens came with single exhaust, to actually use an x pipe you will need true dual exhaust, which as mentioned needs to be fabbed up custom and is a real pain in the **** to do, a good place to start is with a nice set of long tube headers. Senior Member
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Try looking at this. They have great kits for our cars and they have a car well into the 9's with one of there kits. So unless its needed this might be a way to go.
http://www.mufflex-performance.com/
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i put one of those 3" universal xpipe kits on mine with headman longtubes, heaman 3" extensions, and turn downs, all custom by me and i get ppl asking me where i got my exhaust from all the time. havent heard a system on a third gen that will come close to the sound of a true dual with xpipe setup.
as said above to get one would require some skill and custom fab work. most shops wont do it on a third gen. depends on wat exactly u want.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
http://www.youtube.com/watch?v=pcMrnqWe9ms
Sounds pretty good for a stock L03 eh?
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
This is what I'm installing on mine. The plan is to cutoff the Mufflex Y-Pipe and tie this in to a Flowmaster Y merge before the rear axle.
http://www.flowmastermufflers.com/pr...oducts_id=2323
Car: 87 TA clone
that kit doesnt look all that great for that price. the xpipe itself in that flowmaster setup is only connected at a very very small part. especially with a 3" system. a larger opening between the individual pipes will offer and perform much better. thats just for a tighter fit.
i would get a nice magna flow they are tight as well but offer way more flowing than that, its stainless and is only 100$ alot cheaper than the flowmaster one. u should have enough room for that where the cat goes.
it utilizes the straight in and straight out design, u wont have a prob with this if u can fabricate the pipes from the headers in and then out. just dont put an xpipe on a car that will go back into a single pipe or u will be defeating the purpose.
http://store.summitracing.com/partde...5&autoview=sku
hectre13
Sep 8, 2015 03:38 PM
transaero
Aug 31, 2015 01:14 AM
thanks.
