SS vs. Coated Headers
Old Dec 16, 2007 | 07:53 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
I will be installing headers this winter. What are the advantages vs. disadvantages between the two. What I'm looking for is, "the better header".
Old Dec 16, 2007 | 09:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: SS vs. Coated Headers
Coated headers look better and provide more benefit in the form of cooler temps than stainless steel.
Old Dec 23, 2007 | 06:33 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
they look better for a few years.......eventually even the best coating breaks down.....especially after being scratched a few times....which is inevitable with working on the car around the headers and what not.
I've had coated hooker super comps for about 5 years now.....if i had it to do over again, I'd get the stainless headers.....and when i replace these it'll be with stainless
Old Dec 23, 2007 | 07:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i liked my jet hot coating... few years on them and they still look pretty good. definately helps keep heat inside the exhaust, and reduces underhood temps. they dont radiate the heat as much. they cool faster too.
Old Dec 23, 2007 | 08:15 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I have the jet hot coated headers on my 81 Z-28 and my 89 GTA.
The 81 long tube dynomax headers have been on the car for almost 8 years,and have no complaints.
The hooker 2460's with y-pipe that I purchased have only been on the car for a few months and are holding up very well.
So I think the coated headers are just fine.
The ss might last longer,but they have a big price tag difference to go along with them.
My jethot coated hooker 2460's are holding up just fine.
Old Dec 23, 2007 | 08:35 PM
Car: '91 Camaro RS
it has alot to do with how much work you do on the car......i've had the engine out of the car at least 7 times since i got them.......thats alot of accidental bumping and scraping........you could always buy SS headers and have them jet hot coated i suppose
Old Dec 23, 2007 | 08:42 PM
or you could just figure out what you want to do before you buy your headers, and break the engine in with some similar junk headers.
Old Dec 23, 2007 | 09:03 PM
Car: '91 Camaro RS
its got nothing to do with breaking the engine in, its about blowing up parts drag racing......changing combinations etc......didnt really have alot of choice as to how many times i took it apart
Old Dec 26, 2007 | 02:15 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I would say coated because it helps retain the heat in the header and aswe all know heat is an energy and when you keep the heat moving through the header and not trying to get out ot the header you increase your velocity and remove the exhaust gas faster
Old Dec 26, 2007 | 07:10 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I had the SLP stainless steel headers on my car for about 13 years. Then during an upgrade of the motor I had them ceramic coated. Best of both worlds.
Old Dec 26, 2007 | 10:21 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
All the information is here. For durability, Stainless, for thermal efficiency, coated, but the coating will eventually break down, especially inside the tubes.
Best of both worlds, Coated Stainless.
TA
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
3.8TransAM
Sep 17, 2015 02:16 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
