white smoke from exaust?
Old Jan 7, 2008 | 08:59 PM
34243camarokid's Avatar
Car: 1992 chevrolet camaro rs
Engine: 305 v8 5.0L TBI
Transmission: atomatic
for my 17th birthday i got my 1992 chevrolet camaro rs tbi straight piped from the manifold to a flowmaster muffler,and it ran finr for 2 days,but now its running fine,and theres lots of white smoke comeing from the dule tips,can anyone tell me why that is happening?and it also smells like its burning really rich,any suggestions?thanks
Old Jan 7, 2008 | 09:07 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: white smoke from exaust?
white smoke usually means a blown head gasket.
Check your oil and water levels. As its running look at your overflow and see if it bubbling in there
Old Jan 7, 2008 | 09:12 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
You sure its not just because the weather is just getting really cold outside?
Normally, alot of white smoke out the exhaust would mean somehow antifreeze is getting burned in the motor. This usually means a bad head gasket, or cracked head. That would be like worse case scenaro, though.
It could also be the new pipe burning in. New exhaust always stinks for a week or two, and sometimes emits a very slight puff of smoke. But anything you can notice could be serious.
I would try smelling the exhaust. If it smells kinda sweet / tangy, it is probably coolant. Coolant steam has a distinct smell, I used to drive a parts truck around with 2 cracked heads and I got to know that smell real well.
Old Jan 7, 2008 | 09:34 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
white= coolant
blue= oil
Old Jan 7, 2008 | 09:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
nice AVATAR , i'm sure it will draw lots of helpful info. from the forum .
Old Jan 8, 2008 | 12:05 AM
alright guys thanks,so its ether pipes burning in,or posibly coolent
but it does smell sweet/tangy,i smells like the exaust isnt being burned thuroughly,i was thnking more along the lines of back presure change,no?,cause i know onsme cars if u changed that back presure then the engine needs a lil tuning,but i guess i'll try one thing at atime i guess i'll go with new pipe burning in first,and if it keeps up,i'll go with coolent,and if thats not it then i guess i'll be asking arun agine
Old Jan 8, 2008 | 03:41 AM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
When I had my duals installed, the pipe had a "hot" smell for a few days, but no smoke. I have seen engines smoke white due to overly rich conditions. But that is more common on carburated engines, and usually comes after a hard acceleration then lifting off abruptly. Or between gears on a manual trans, either way same thing. I would just take it easy on the car for a few days an see what happens. Keep close watch on the temp. And watch to see if your coolant level drops any, and your oil will start to turn a milky brown color (sometimes has bubbles in it) if its getting water/coolant mixed in.
Good luck,
Max
Old Jan 8, 2008 | 10:11 AM
thanks max,yeah its carb'ed and yeah i did excelerate hard but that was just to see how it sounded at high RPMs and because the guy that did the exaust sayd it would give me a 25 horse gaine,so i was seeing if it was true,but yeah i think im just gunna try for 1 thing at a time useing the suggestions evryone has given me,and if it keeps up im just gunna take it to a machanic,i'v got a messed up gas gage as well so i'll have them take a look wile fixing the gauge
Old Jan 8, 2008 | 11:44 AM
SteelTownMadDog's Avatar
25HP from an exhaust with stock manifolds? Yea, I also heard adding a Flowmaster window sticker will give you an extra 5 HP. Give it a shot!!
Old Jan 8, 2008 | 09:16 PM
DUDE!!the flowmaster sticker worked!! ,but yeah the exaust did improve the throttle responce though,and it finaly stop smoking so much,now its just a little and you have to be really close to see it,but thats probubly because of new pipes,so im not gunna worrie about that anymore,but i need a new tranie mount,and my gas gauge is broken,but im getting thoes fixed soon
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
