the best header gaskets?
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
I have a 91 t/a 5.0 tpi w/ elderbrock headers flowing into one 3" y, no cat, straight pipe 3" to a flowmaster with 3" inlet and two 2 1/2" tail pipes.
The car also has an accel ignition system, 8 mm wires. Don't think that would madder but?
Anyway I keep blowing the gaskets out, its not just one cylinder so I don't think the headers are warped, I've replace the gaskets 3 time last year. I'm currently using the single port thin metal gaskets.
I've heard talk of a aluminum gasket that is the cats meow?
Thanks,
Rich
Thanks,
Rich
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: the best header gaskets?
I have a similar setup, 91 TPI 5.0 5 speed, Hooker 2055's Jet Hot coated, Magnaflow 3" cat Flowmaster 3" 1 in 1 out...
I used Percy's soft aluminum gaskets... there are other's, but they crush when tightened... But I also have a set of Breslin Locking bolts to keep tight.. a little less hectic than the Stage 8 or wire tie... No problems...
Raf
Raf
Car: Forrest 91 t/a
were did you get the gaskets? locking bolt's? god it's already hell getting to the last bolt on the starter side.
http://www.remflex.com/
do you know anything about remflex? I just don't want to do it again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Breslin Bolts...
http://search.ebay.com/search/search...der&category0=
be sure and get the correct ones for you motor (right length) or you can damage your heads, pierce water passage ways, etc...
I bought the gaskets on Ebay too...
http://cgi.ebay.com/ebaymotors/Percy...2em118Q2el1247
Looks like summit probably sells them too.. I think local auto parts stores may have them too & other brands... just remember, soft aluminum.
Raf
Raf
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
summit sells them, just look for soft aluminum header gaskets. they are the best.
but copper works good as well, aluminum is a sure fix tho
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yeah I've had copper gaskets leak on me before.. it was on a set of flowtech crap though...
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Earl's, the best ones I've used yet. I had the bolts fall out and the gasket didn't blow. They also have replacement inserts so you don't have to buy the whole thing everytime you take things apart.
Here's the # I use from Summit.....EAR-29DD3BERL (D-port) 1.55x1.63
Car: Forrest 91 t/a
Thanks for the info, It sounds like aluminum is the way to go. I am interseted in the rimflex gaskets.
I like that there are no special bolts and they will seal up to an 1/16".
But, I'll problem go with the alum. its a tried and true fix
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
I used copper gaskets on hooker 2055's with stage 8 locking header bolts and never had a problem. I think one of the biggest problems with gasket leaks is botls backing out and people over torquing them. Also make sure mounting surface is clean on your headers and heads. I used one of those green scotch bright pads you can get for a die grinder...takes all the crap off but does not take the metal off.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I also have had good luck with Earls header gaskets. Like Don siad you can lose a bolt and they still seal. I also like the Breslin style header bolt. Between the two no header leaks.
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
This is an easy question. Alum or copper header gaskets, and locking header bolts, i have not had a header leak in 4 years.
Chad Speier
Sep 24, 2015 12:32 PM
