Are FlowTechs any good?
Old Jan 20, 2008 | 01:26 AM
Shadowman's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Seen shortie headers and y pipe combo for about 290 in a summit mag and wondered if this brand was any good or not.
Old Jan 20, 2008 | 01:35 AM
ccook-92-305's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
Re: Are FlowTechs any good?
Ive had mine for 4 years now, no problems and huge sound difference. Love em nd it looks like they're still holdin up great. Granted i havnt compared them to anything else but with that setup 3" backpipe into a flowmaster 50 dual out sounds pretty mean for my lil 305.
Old Jan 20, 2008 | 01:40 AM
Car: 1992 Camaro RS
Engine: 305 TBI
http://vids.myspace.com/index.cfm?fu...deoID=22921946
Old Jan 20, 2008 | 01:45 AM
Shadowman's Avatar
Engine: 305 TBI
Car sounds sweet man. Ill look into these then. Thanks
Old Jan 20, 2008 | 02:09 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Flowtechs are at the low end of the header scale. Better than manifolds, but on the small side for serious use. There are much better alternatives.
Old Jan 20, 2008 | 07:07 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i bought a ceramic set a couple of years ago . had to spend half a day cleaning them up . weld splatter on flanges , "Y" pipe connection on the inside not fully open . not the best , but not the worst . i used a mr. gasket copper on the flanges to the head and soft seal alum. on the "Y" pipe . ( DON'T USE THE PAPER ONES THEY GIVE YOU ) oh yes , use new header bolts with locktite . tighten from the center outwards , you will need to make spacers for alt. and a/c comp. . all in all not too bad a set of headers , but for sure not the best .
Old Jan 20, 2008 | 11:37 AM
Car: 1992 Camaro RS
Engine: 305 TBI
yea im sure they're not near hooker or hedman quality but for a 305 that will hopefully b swapped out someday anyway why spend a buncha money on it? that was my reasoning anyway. i dont kno if you're runnin a 350 but im sure they would still flow better than stock. be ready to drill some bolts out cause you'll probably break one off in the block, soak them in penetrating oil for a good while before you start too.
Old Jan 20, 2008 | 11:45 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
What did you use to drill them out? I cant imagine a cordless drill fitting up under there to drill out the heads. Did you have to re-tap the holes?
Old Jan 20, 2008 | 12:36 PM
Car: 1992 Camaro RS
Engine: 305 TBI
well long story short we tried it with a 90 degree drill nd ended up messin it up so we hada take it nd have the head pulled im sure the mechanic re-tapped it but its been 4 years ago so i cant remember...
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
