i need my exhaust 5DB quieter
Old Jan 28, 2008 | 08:20 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
exhaust help needed. i have a 350 TPI with 1-3/4" SLP headers, and a 3" hooker aerochamber catback. it fails Oregon DEQ noise check by about 5 DB. i need it quieter. what can i do as a temporary cheap fix? just something temporary i can yank off later.
ideas?
Old Jan 28, 2008 | 08:36 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: i need my exhaust 5DB queiter
jsut a thought, but some coarse steel wool. and put in the tail pipe w/ a steel fishing leader so that you can pull it out after
Old Jan 28, 2008 | 08:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they make perforated cone baffles that install in the tailpipe, jegs # 329-72-32520 70 bux though.
http://www.jegs.com/webapp/wcs/store...10002_59838_-1
could put it before the muffles, or around the cat i guess, whatever is easier
Old Jan 28, 2008 | 08:43 PM
Xophertony's Avatar
Axle/Gears: n/a
yeah, someone else mentioned that as well.
Old Jan 28, 2008 | 08:54 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Make your own lol its easy cheap and fast, find a 3in empty soup can, drill about 6 3/8" holes in the bottom of it, put some steel leader wire on it (so you can pull it out) and put it in the exhaust pipe before the cat or somewhere that will hold it in place........ did that to a friends car and it worked real good, and was easy to install and remove.
Old Jan 28, 2008 | 09:22 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Try cramming an old sponge up one of the tailpipes. Make sure you have a way to get it back out tho. If you use that to make all the air come out one side, it should at least be a little quieter.
Old Jan 28, 2008 | 09:52 PM
Xophertony's Avatar
Axle/Gears: n/a
all good ideas thanks
Old Jan 29, 2008 | 03:48 PM
Pocket's Avatar
Car: 91 Trans Am
Steel wool will come out with a good WOT burst
Be gentle on it until you leave the inspection station
Old Jan 29, 2008 | 03:52 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
I have no idea if it will work but make your air filter dirty, less air equals less noise
Old Jan 29, 2008 | 08:42 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
roll up some steel window screen. wedge it in.
That jegs thing looks to be the best option tho.
Old Jan 29, 2008 | 09:27 PM
Engine: LO3
The only think I can think of that is, since he has a Aerochamber, each tip is like a y-pipe. That makes getting stuff in and out kinda a pain I bet.
Flowmaster tips would have been super easy!
Old Jan 29, 2008 | 10:02 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Wow....i really didnt know anyone had sound segulation on inspection.....G A Y.
Old Feb 2, 2008 | 08:16 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
a permanent solution would be a bullet muffler in the intermediate pipe, or cut the hooker tips off. they add just a touch of noise over a regular type tailpipe.
steel wool is going to be your best bet.
Old Feb 2, 2008 | 09:55 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Man, noone mentions what I do. Just find a garage that isnt run by a bunch of dicks. Problem solved!
Old Feb 2, 2008 | 11:59 AM
Engine: LO3
Well, dicks or not, if they are using a DB meter, they dont really have a choice. Unless they ghost it, but that is probably a punishable crime.
Old Feb 2, 2008 | 01:47 PM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Can you please explain how the hooker tips are louder than other tips please
Old Feb 2, 2008 | 06:41 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
just by their design. they resonate.
Old Feb 2, 2008 | 09:24 PM
Engine: LO3
I dont really think they would sound all that different from any other 3" single tip. Only difference is the Y at the very end. Its not like there is 4 actual tips.
But yes, I think every tip will change the sound to a limited extent.
Also remember, sound decibles arent a linear scale. It is more like exponential. I think the rule of thumb is every 10 decibles, it is actually twice as loud. So 90db. is like twice as loud as 80db.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
