Exhaust Ideas. 1986 305 TPI
Old Feb 7, 2008 | 02:36 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Ok everyone I need an idea of what I should do for my car. Preferable custom.
My idea was to have straight pipes from the headers to a dual cat and catback, leading out to 2 mufflers out the back.
It was a cool idea to me till someone said it wouldn't work. Now I'm lost and not sure of what to do.
I want something loud. Even louder than the car already is. Help is much apprieciated
Thanks,
Firebird896
a.k.a
Firehawk896
Old Feb 7, 2008 | 10:57 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Exhaust Ideas. 1986 305 TPI
"Loud" is a very vague description. Some people think that a Flowmaster 80's series is too loud, others will say that open headers aren't too loud for daily driving. You would have serious ground clearance issues with your proposed idea. Maybe you should check out the Third gen Dual Exhaust Picture Collection sticky up top for quite a few great example of what you could do.
Old Feb 10, 2008 | 05:23 PM
Engine: 350/350/LS1
Bump
anything with 2 mufflers out the back
Old Feb 10, 2008 | 11:06 PM
Engine: 350/350/LS1
BUMP
Old Feb 11, 2008 | 12:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
are you wanting to do true duals? it can be done but will depend on how you route the pipes and how low the car sits.
If you are using shortie headers, you can run true dual 2.5" down the factory location possibly into 2 cats if you need them, and then over the axle into 2 bullet style mufflers.
check the sticky on the top of the exhaust board for true dual exhaust picture collection. that will give you ideas
Old Feb 11, 2008 | 08:40 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
http://www.cardomain.com/ride/2197664/8 check this out....i am modeling my true duals after his
Old Feb 11, 2008 | 04:56 PM
Engine: 350/350/LS1
89formula350b2l that is the exhaust im looking for. Do you have a layout of how to do it
Old Feb 12, 2008 | 04:55 PM
F41eatsFords's Avatar
There is a true dual setup that follows along the origional routing, for like $165 on Summit. I think it's a dynomax. pipes only, and either 2.25 or 2.5 OD. either way, seems like a reasonable price. check it out.
Old Feb 12, 2008 | 05:25 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
I'm liking that exhaust idea myself. I'd just do 2 flo pro mufflers with no cat with 2 4th gen Z28 exhaust tips (already own a pair).
Old Feb 12, 2008 | 06:15 PM
Engine: 350/350/LS1
Anyone esle with some exhaust ideas. I want to have something loud inside and out. Ground clearence is not a problem but do go over a big speed bump everyday
Old Feb 12, 2008 | 07:37 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
This guy is a member here, but I dont know if he is still around. Anyway, here is his sweet setup:
http://youtube.com/watch?v=a5HNA9TVvc8
Old Feb 12, 2008 | 08:59 PM
Engine: 350/350/LS1
That is a pretty good idea. What about having a double cat and catback. I know I have to push the idea though of having double.
Old Feb 12, 2008 | 09:39 PM
VonKaiser's Avatar
Now that guy's Camaro sounded insanely awsome. I'm liking the cutout rear bumper too.
Old Feb 12, 2008 | 09:43 PM
Engine: LO3
Yeah, I think that camaro sounded pretty good for a stock 305 TBI.
Old Feb 13, 2008 | 07:16 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
The more powerful the engine, the louder it is. I didn't think so, until I built a full roller wicked little 327. Even with a "quiet" exhaust it is blasting loud, so much so that I may end up using 4 mufflers on the car to keep it more stealthy. W/ a big roller cam and aftermarket heads the tone is just so radical I can't keep it quiet enough for me.
If you want a really loud engine, build a powerful powerplant. The mufflers will then be a secondary consideration.
Old Feb 13, 2008 | 07:54 PM
Engine: LO3
Good headers have alot to do with volume, too. Along with your catalytic convertor.
Old Feb 13, 2008 | 08:34 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
I installed true duals on my lowerd to the ground 85 t/a. Ground clearence was an issuse, so i build the system out of 2 1/2 oval exhaust tubing i got from Dr gas. At the time of the pics i had put my old flowmaster on, till it fell off and i loved the sounds the straight pipes made. {Sounded like the brick yard 500 everytime i took off down the road} Since then i bought two magnaflow oval 5 x 8 muffs and ran the pipes to the small space on the sides of the trunk well. Sounds great. Definatly not loud, but i ganed so much tourqe, and i like the stealth sound it has till i uncork it. ill put up some pics of the finished mufflers. when i get a min. oh yeah, some assembly required,
https://www.thirdgen.org/forums/exha...wered-3rd.html
Old Dec 24, 2010 | 12:22 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Sorry to bump such an old thread (I found this thread in a Google seach looking for TPI intake images), but I think somehow the pictures that were in this post have been changed at the site it was hosted at. It IS still a sweet setup tho.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
