Cheap way around true duals or 4 inch pipe with 383
Old Feb 26, 2008 | 07:20 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I am going to have 1 3/4 shorties with 3 inch cat back. If I put a cut out where the cat is suppose to be do you think I would have enough flow for my engine when i go racing. My specs are in my sig. All the other options seem to be way to much work or to expensive. Running a true dual will give me horrible ground clearance for the streets, and going to a 3.5 inch or 4 inch pipe will cost around 5 bills. So I was thinking I really only need all my power at the strip and not on the roads. Let me know what you guys think
Old Feb 26, 2008 | 07:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Cheap way around true duals or 4 inch pipe with 383
3" mandrel bent exhaust with dynomax ultra-flow muffler with cutout for track will be fine.
Old Feb 26, 2008 | 08:05 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
onefreakz
May 14, 2018 12:15 PM
billybob6110
Sep 24, 2016 09:50 AM
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
