valve spring/exhaust question
Old Mar 9, 2008 | 05:58 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
If i put in an exhaust cutout for the occasional trip to the track, will i have to worry about having enough backpressure for the exhaust valves to function correctly? the engine has only around 20k (acdelco reman). i have been told (not sure if its accurate) that the factory springs require a certain level of back pressure to return to the closed position.
thanks,
Jason
Old Mar 9, 2008 | 06:00 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: valve spring/exhaust question
negative.
the springs are all mechanical.
run the cutout, or open headers if you want.
Old Mar 9, 2008 | 06:01 PM
thunder85's Avatar
Engine: 5.7L w/hsr
cool. that makes life much easier for me.
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
