Header warp changes bolt spacing
Old Mar 13, 2008 | 09:09 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ever see this happen on a header that has 3 flanges, instead of a 1 pc flange? Both sides, must have warped at on etime because the bolt holes and ports are off by like 1/4". I was thinking just heat them up and bend them over with the portapower. What do you folks think?
-- Joe
Old Mar 13, 2008 | 10:15 AM
ljnowell's Avatar
Re: Header warp changes bolt spacing
ive never had anything like that, but once i used flowtech headers. Out of the box they were so warped that unless you put all the bolts in and slowly tightened each one a little and went from bolt to bolt they would work. Literally if you started at one end, by the time you make it to the other the bolt holes were completely missing the holes in the head. it sucked.
Old Mar 13, 2008 | 11:12 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hrmm. Well these are hooker headers. They have flanges sorta like SLP, 3 individual flanges.. oh well. Guess I'll fight with it. They are like $600 new so I'm not throwing them out.
-- Joe
Old Mar 13, 2008 | 11:16 AM
ljnowell's Avatar
-- Joe
I would think a little persuasion would do it. Ive never tried to straighten them when they were that far off. If you have an old cyl head, maybe you could put it on a bench and use a torch, heat the hell out of it and try to attach it to the head? I dont know if it would damage the header too much or not. Or maybe it just needs a little manual persuasion with a long pry bar?
Old Mar 13, 2008 | 11:26 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't want to pry it on the engine since the heads are alum, and my experience with alum heads is the threads like to pull out.
I do have some junk 327 iron heads on the shelf, I can bolt it to that, heat it up and pry it a little I guess. I'm kinda surprised these are so far off. and both identical.
At first I thought, "oh joe you stupid idiot, these are LT1 headers the LT1's must have different exhaust bolt pattern", but some searches here reveal that folks with LT1's use normal SBC headers with no problems..
-- Joe
Old Mar 13, 2008 | 11:29 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Did you trial fit the headers before putting on the wrap?
Old Mar 13, 2008 | 11:42 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Wrap? no wrap here. I bought them used. They're plane, almost polished steel.
Lets see if I can't attach a picture. If you're looking at the header, the left and center primaries will bolt up, the right primary is too far INWARD towards the center to catch the bolts. Both of them are warped this way. really strange. I paid short money for them, but new from summit they are $615.
-- Joe
Old Mar 14, 2008 | 07:33 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Sorry about that. I had wrap/warp both on my mind.
You might put the center primarys on a table vertically. Then use a port-o-power or sizzor jack to spread it apart.
I have a set of Hedmans with a single flange. I had to cut the flange between the primarys and do the same thing. Worked great.
Old Mar 14, 2008 | 10:26 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well then, that is what I'll do. Once of course, I get over this freakin cold.
Thanks for the reply guys. TGO is great.
-- Joe
Old Mar 14, 2008 | 10:48 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
you'll probably just have to fight it. This will happen to cast iron manifolds as well. I've had to use a nut/bolt like a jack screw to get them lined up. Bolt the center flange on, then use a spreader to get them right OR, since you have a set of heads laying around, get them on and spread, then weld a strap between them to prevent this from happening again.
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Genopsyde
Aug 22, 2015 06:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
