Bad luck with headers...
SO i found out the other day that i had to again buy another set of headers... this will be my 3rd set in a little over 2 months.
The first set just got legitimately damaged by a "custom" y-pipe that i had made.
And the second set ended up being the wrong size? (Flowtech...) and was rubbing up against the frame..
I found a third set that i think should work but could you guys check it for me??
http://www.jegs.com/i/Hedman/500/68481/10002/-1
It said on the Hedmans website that they would come with a y-pipe, but i wont actually be ordering them from the Jegs website. So in case they dont come with one could someone link me to the stock y-pipe dimensions or at least a pic so i can have one made???
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Bad luck with headers...
Any reason why you haven't considered the Hooker 2055's, a board favorite?
JamesC
JamesC
Car: 1991 Chevy Camaro...
Engine: 406 With Many Mods..
Transmission: Turbo 350...Hurst Quarter Stick...
Axle/Gears: 373 Gear..Posi Rear End...
I used the HOOKER HEADERS they bolted right on up...All I can say is.......
"LOVE EM"....No Offence but it sounds like you are spending a lot of cash on a simple thing....
Last edited by BAD INTENTIONS; Mar 16, 2008 at 09:22 AM. Reason: ummm typo yeah that's it....
But about the Hooker 2055 they are on Jegs for $455 (but i wont order online for these, ill order for a local shop)
are these worth the 455? and is there anyways to get ride of the AIR, i dont have any of the other components to run the AIR
Car: Pontiacs, Jeeps
Oh, you should've said that. Well you could always cut them off the 2055's and weld up the holes but that will probably start the rusting process that much faster. There are other headers that are made without the AIR tubes on them, I just dont have the part # for them. If I have some time later I'll do some looking around.
Do you need a Y-pipe, or do you already have one?
http://store.summitracing.com/partde...5&autoview=sku
and the uncoated but super cheap:
If you need the Y-pipe:
If you look at the 2055's and these 2460's you'll see the pipes run the same way, the only real difference is the collector.
but other than that...
omg... you just saved me. Thats amazing!
Thank you!!!
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
I have a set of Edelbrocks that I had to work with a bit (a few sets of gaskets) but otherwise are working great and fit well.
The short answer, yes. How long will it take to actually rust through and leak? That I cant answer,but it will take awhile. Remember these fancy coatings have only been around since the '80's. Uncoated headers have been around forever and people have used them for years with no problems. As far as looks, you cant beat the coated headers though. It just depends on what you're looking for and what you can afford. Personally, if you can afford it I would get the coated.
Transmission: 4L80E/4L80E
Dyno Don's seem to be a good value, though. He'll make them with or without the A.I.R. tubes. I believe his are only 1-7/8" primary tubes, which would take a healthy 305 or 350 to be worthy of them.
The other possibility is the Hedman dual cat headers. Nice mandrel-bent down-pipes to the cats, you don't have to use dual cats ("Y" the pipes together). They also have the A.I.R. tubes - same solution as the 2055's if you don't want the A.I.R. tubes.
Other than the fact that you'll have to grind off any paint that is on there to do the welding. Even if you re-spray them, it will rust faster. Trust me, former body man here. Im not just making **** up.
