what do you think about glass packs
Car: 1982
Transmission: 350
im going to be putting a dual exhaust on my 82 camaro with a 350(long tubes with glass packs and dump off somewhere before the rear axle). i was planning on just putting hedman glass packs on it. my question is what do you think about glass packs, is my car going to be ridiculously loud, is it going to have a deep sounding idle? ive never herd glass packs on a v8 only on the rice burners lol so i dont know what to expect
thanks,
john
thanks,
john
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: what do you think about glass packs
glass packs dont even flow that well compared to todays muffler its old technology its gonna sound like an old pickup, and yes its gonna be ****in loud if ur runnin long tubes and dumpin before the axel. yo look into "power sticks" theyre straight thru chambered mufflers and they sound great
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
I think glasspacks are one of those sounds that, well a V8 with dual glasspacks is like one of the defining sounds of our automotive heratige.
Unfortunately, many others believe that they are one of those things that should have been left in the 70's and 80's along with denim coats, mul-let haircuts, and billy beer.
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
i curently have a cherry bomb glasspack on my car (mines single tho) i have it hooked up right after the downpipe an i think it sounds pretty fkn good
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Personally glass packs sound decent on an old farm truck but I can't stand loud exhaust that pops. The best sounding exhaust in my opinion is a dual exhaust setup with X pipe and flowmasters or spintech.
Car: '89 IROC-Z
Engine: 355
those cherry bombs are a steal at 20 bucks a pop i also heard if you break the glass on em they sound even better
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
well my exhaust is loud but it dont pop unless i make it. And it sounds pretty good but im not done yet still gotta run a pipe out the side, its just a temp fix till i either get one made or buy a whole system
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i'd say go for it but get Thrush glasspacks- i have one on my car and it sounds great. Thrush glasspacks have smooth openings on the inside casing as opposed to other brands which have little notches sticking up to "catch" the exhaust causing turbulence and a not-so-good sound. my car has a glasspack and i have an LG4 and it def. does NOT sound like a truck or some red neck POS.
pics:
http://punkdude908.myphotoalbum.com/...umName=album03
video:
http://www.youtube.com/watch?v=3YjXNMVbWMw
pics:
video:
Car: '89 IROC-Z
Engine: 355
yeah the thrush ones dont have the loovers theyre straight thru so they flow better
Car: 1982
Transmission: 350
ok guys thanks for all the info youve gave me some different options well when i finally figure out what im gonna do ill let you all know how it turned out...and punkdude if i do decide to throw some glasspacks on it id hope that it would sound your car it sounds pretty good man
thanks,
john
thanks,
john
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
The biggest issue with "glass packs" as sold by a neighborhood muffler shop is that they use low quality packing that burns out, and not much of it. You'll find that a longer glass pack actually sounds good (somewhere around 18-20 inches long) and flows well until the glass burns out, then it just becomes a turbulence factory. They are also often limited by the internal diameter. Look up DynoMax Race Bullet # 24219, 3 inches straight through, 18 inches long. They're about 50 bucks from Summit, and gave us the best results on the dyno and at the strip. Not too bad at idle and low speed, and sounds like a NASCAR stocker at full honk.
TA
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
liteumup387 bro check it out i have basicly your setup except i have flowtechs headers and short glasspacs sounds pretty damn good two me better than the 18" i like it cause it sounds alot like the old camars and birds of the 60s 70s and goes swell with my crager ss,S, i have duels down mine and short glasspacs have great ground clearance also if your going true duels. i have seen glasspacs come straight off your headers and that sh*t is really loud, however i dont think it would work on our thirdgens.
Engine: Tbi 305
Axle/Gears: 3:73s
Yea lol when im wot and let off it pops and cracks like crazy but i love that about it. i guess i can see where it get old two some people that drive there third gens everyday but i olny drive my Bad Bit*h on the weekends
Axle/Gears: 9bolt
Uh, to each his own. Maybe it would be a good idea when talking about exhaust to state your age and what you want from the exhaust.
I'm 47 years old, and I want to make the most power with the LEAST possible noise. I'm feeling like I'm in the minority here.
TA
TA
Car: '89 IROC-Z
Engine: 355
Im 19 and I want my exhaust to flow good AND be loud but not just loud but sound good also
Car: 2000 BMW M5
Glass packs are loud, but not good loud. They will make a V8 sound like a combination between a gang of harleys, and a construction dump truck. I have run them on several V8 dual exhaust setups and a few single exhaust V6 stuff so I am well versed.
TA you are not alone. I am 24 and I have had my share of open header $500 POS cars that went slow and made a ton of noise doing it. I am over that phase and now seek to make maximum HP with minimal noise. Most of the loud cars on the street are really slow lame-o V8s (and 4 bangers for that matter) that some kid just wants to make a racket with anyway.
If you want to hear glass pack sound clips, here is my brother's 66 Dart, which was a 318 w/ Magnum heads (1.96/1.6 valves), 0.470" gross lift cam, stock manifolds, and dual 24" long case cherry bomb brand glass packs
There are two video clips so you can hear it. It doesn't sound "that" bad but it is extremely flappy. Going down the street it would go blapblapblapblap, more like a motorcycle gang than a high performance car.
http://s170.photobucket.com/albums/u...t=MVI_0062.flv
http://s170.photobucket.com/albums/u...t=MVI_0065.flv
Here's two more video clips w/ sound from inside the car:
http://s170.photobucket.com/albums/u...t=MVI_0041.flv
http://s170.photobucket.com/albums/u...t=MVI_0043.flv
Engine: Tbi 305
Axle/Gears: 3:73s
lol bro i see where ya comin from ....but my Camaro with a 305 and flowtech headers with 2 12 inch stainless steel glasspacks sound 3 times better than that. Tell your Brother he should of went with a chevy
Axle/Gears: 9bolt
Those are very long glass packs, but what diameter core are they? Are they true duals? Does it have an X-pipe? Inquiring minds want to know, so they can AVOID making anything sound like that.
Sorry, but Cherry Bombs are just a marketing name somebody slapped onto garden variety glass packs about 40 years ago to make 'em "cool".
Travis, you say yours are stainless, who makes them? How long are they? Any chance of a sound clip? C'mon, you "young bucks" are all computer savvy, right??? If my nephew can download music onto my cell phone, you can certainly download a sound clip fer yer buddies on this board!
TA
TA
Engine: Tbi 305
Axle/Gears: 3:73s
mine are 12 inches long i have an H pipe, However i am not satisfied until i get the catback with some hookers 2055 i have been longing for. and no i have no sound clips sorry man just take my word for it.
Car: 2000 BMW M5
That 318 would have destroyed most 305 cars. That car weighed about 3,000 lbs. I have built more than just chevy stuff and it ran very hard. We don't have the car anymore. It was a total rust bucket. I have run glass packs on a Pontiac 400 w/ headers and it sounded even worse than that Dart did in the vids. Flapalapalapalapa.
Engine: Tbi 305
Axle/Gears: 3:73s
all in all boys its what you like, it doesnt matter what some rich Fu*k on here thinks.. its what you like
its what you think/believe your camaro should sound like.if glasspacks are the deal then let um Flapalapalapalapa as long as you like it....and hell this is off the subject but.. to the ladies, i aways tell them i have like a 454 bigblock over 500 hp and everytime they believe me! and think my duel glasspacks sound amazing so i would much rather impress the ladies than any man on here, i mean come on lol
its what you think/believe your camaro should sound like.if glasspacks are the deal then let um Flapalapalapalapa as long as you like it....and hell this is off the subject but.. to the ladies, i aways tell them i have like a 454 bigblock over 500 hp and everytime they believe me! and think my duel glasspacks sound amazing so i would much rather impress the ladies than any man on here, i mean come on lol Supreme Member
Axle/Gears: 9bolt
Yes, sound is subjective to a certain extent, but most of us agree that the lowrider flappa flappa is not high performance sounding at all. When it comes to impressing the ladies, most of them cannot tell a Camaro from a Mustang from an dump truck, they just act impressed because they think it's important to you. All they care is if it runs well, looks decent, and doesn't stink.
TA
TA
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Please get a nice muffler. Glass packs sound god awful on anything. They sound as cheap as they are.
Car: 92 RS, 87 Formula, 89 IROC, 05 SRT4
Engine: 5.0 TBI, 5.7 TPI, 5.0 TPI
Transmission: 700R4 x2, T-5
Axle/Gears: 2.73, 3.42 posi x2
Glasspacks sound best on a smaller displacement high compression carb'd V8...basically, if you have a ford 289 or a chevy 327 with a four barrel, then glasspacks are good, on more modern fuel injected engines (especially with the long induction tubes on TPI cars) then you're better off going with a chambered design.
Engine: Tbi 305
Axle/Gears: 3:73s
naw i cant really agree with that....i think flowmaster is the better way out for any setup, however when you cant afford flowmaster spintech or w/e glass packs can hit the G spot, for now anyway
Car: '89 IROC-Z
Engine: 355
yeah but carbs have that WAHHHH sound that only carbs have, you can tell a holley from a qjet
Car: 1982
Transmission: 350
thanks for all the info guys... after looking under my car again i realized i better get the front coil springs in because its sagging pretty bad so im gonna do that then order the exhaust parts when i do it ill put up a new post and let you all know what i did how it turnd out
thanks again,
john
thanks again,
john
Glass packs with dumps under the car are a nitemare. The interior turns into a vibration chamber. You need pipes that go out the back. They help the car sound so much better. Don't believe me? Disconnect the exhaust at the back of the cat and go for a ride. The glass packs came out in the late 60s when everybody wanted their car to sound like a musclecar. But with a low compression V8 and mild cam they just sounded like you had a blown muffler.
Ain't nuthin' like a high compression, big cam, carbed V8!
http://www.youtube.com/watch?v=xS7ZN...eature=related
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
i've got a set of hooker shorty's along with their y pipe. i was thinking of sticking a single super 40 or something similar under the passebger seat and dumping soon there after, is that going to sound signifigantly different than the 80 series crossflow muffler i've got in the stock location?
Car: '89 IROC-Z
Engine: 355
haha uh YEAH! it gonna be loud as a mother****er! do it, itll sound awesome and youll have more horsepower
Car: 2000 BMW M5
You're also going to wind up with carbon monoxide in the passenger's compartment because the weather seals are never perfect, and you will be putting exhaust right under the pass compartment. I've dumped under the car once before. Never again.
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Glass packs= shitty sounding lol... Trust me, I have a friend that has them and I hear them everyday on his 88 maro... Sounds like ****!
Engine: 305 tbi
i was thinking of running a short pipe and pointing it sideways in front of the weel under the rocker panel.
Car: '89 IROC-Z
Engine: 355
power=sound!!! glasspacks w/ modded 350=awesome, glasspacks w/ stock 305=****
Car: 2000 BMW M5
That is really what it boils down to. A 305 carb/tpi/tbi with a stock 0.350" roller cam is going to sound like a dump truck no matter what muffler you put on it. The cam is barely opening the valves, so that's the sound you get. I have a 3" exhaust and a Hooker aero chamber on a 305 TPI long block and it sounds like an oldsmobile with a stock exhaust. I have a roller cammed 327 w/ aftermarket heads and headers, and it sounds wild no matter what mufflers are on it.
Axle/Gears: 9bolt
TA
Engine: Tbi 305
Axle/Gears: 3:73s
yea i have two agree with most.. i just got my hookers 2055s and im in love, i dont think i will be putting the cheep glass packs back on my car hell if it was up two me i would run open headers....
but its not... i taken my side pipes off and i realized our cars look better with the exhaust run out the back not out the fu(king sides! im getting a catback asap and never will i niG*er rigg up some crap again, but ya know you guys are saying glasspacks sounds like a dump truck? i wouldnt go that far with nonsence.
but its not... i taken my side pipes off and i realized our cars look better with the exhaust run out the back not out the fu(king sides! im getting a catback asap and never will i niG*er rigg up some crap again, but ya know you guys are saying glasspacks sounds like a dump truck? i wouldnt go that far with nonsence. Member
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
ive got dual glasspacks on my 3/4 ton silverado with a 350. they sounded ok until the glass burnt out now it sounds like a bag of popcorn in a microwave. it still sounds good at idle and normal (speed limit) driving, but when i get it to WOT it screams on acceleration and it pops on deceleration. IMO just put some thrush welded chamber mufflers on it. i have them on my camaro and they soud good no matte rwhat im doin. there just flowmaster knock-offs.
ack in December, I replaced the original exhaust on my boss's 89 TBI 305 Formula.
I installed the Walker Dynomax Super-Turbo Cat Back. The system went on in 10 minutes and the car sounds great. Sorta deep sounding at idle and it will talk to you but it is not cop-baiting loud.
I got it from Summit Racing- Check it out : WLK-17493
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Thrush Magnum mufflers are made by Dynomax, very cheap, flow well, and have a deep but mellow sound.
Only one tiny warning, the 2 1/4 inlet/outlet version (stock exhaust piping on most of our cars) has an inner tube of 2 inches, while all other Thrush Magnum mufflers have inner tube of same size as inlet/outlet.
