Just an idea I had, what do you all think?
Car: 1991 Camaro RS
Engine: LO3
Re: Just an idea I had, what do you all think?
If you have the welding skills, it can be a much cheaper alternative than a borla, but you still get the adjust ability and if you (Like me) live in a snobby neighborhood, you can quiet it back down before driving into the neighborhood at 3am...
Car: 1991 Camaro RS
Engine: LO3
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Rattle? I don't know. I had one and enjoyed it. Sold it for a more linear exhaust system.
Car: 1991 Camaro RS
Engine: LO3
To run a summit brand manual cut out, well, this is essentially the same thing. This also makes it harder to access, unless you run some pipe to the side. That is also non adjustable. Its on or its off.
By using a system like I am talking about, you would save hundreds (If you can weld) and you would have adjustably on your system. You also dont have to worry about exhaust in the car.
Car: 1990 Camaro RS
Engine: L03 305 TBI
Something like this would flow pretty good, and be much easier/cheaper to build. Don't laugh at my uber paint skillz...
Car: '02 Z06
Engine: L33 5.7
get long tubes, have a cutout come off each collector, and run the rest of the pipe into a Y behind the transmission?
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
To me, the OP's sketch kinda reminds me of that race car exhaust (was it used in the IROC??) that was made by walker back in the 80's, and it used a stock y-pipe and I-pipe, but tacked on another I-pipe under the left side, and had dual side exit with plates...
