Different Header Question
Old May 30, 2008 | 08:27 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
OK. I'm probably asking a lot, but which header is the easiest to install, is durable and will make decent power on a lightly modded L98? I've done a search and it seems like most folks tout SLPs. Are they still king? Will I need a new Y-pipe? Thanks!
Old May 30, 2008 | 09:44 AM
not one's Avatar
Car: 1984 camaro
Engine: weezing 305
Transmission: th350
Axle/Gears: 7.5 3.23 mini spooled
Re: Different Header Question
i believe the slp's where discountinued,not for sure.although the hooker 2055's they appear to be the board favorite.
Old May 30, 2008 | 09:52 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
get them used off the classifieds
Old May 30, 2008 | 11:42 AM
danziger's Avatar
So no more SLPs. Do the Hookers need a Y-pipe, or will they bolt to the existing one? Thanks again!
Old May 30, 2008 | 03:28 PM
not one's Avatar
Car: 1984 camaro
Engine: weezing 305
Transmission: th350
the 2055's come as a kit there are the headers and a y-pipe.
Old May 30, 2008 | 04:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you have the money, look up DynoDon here on the boards, he sells headers that are pretty much "improved version" of the slp's, 1.75 primaries, with the clearance problems fixed and a much better y-pipe. Im sure they are not cheap, but they look very nice, and they are coated
Old May 31, 2008 | 05:16 AM
danziger's Avatar
Thanks for the replies! I don't think I need 1 3/4" primaries on a stock L98 though, or do I? I'll definitely look into the Hookers and check the classifieds.
Old May 31, 2008 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Wherever you buy, make sure the Y is included (the OE Y won't bolt up and fabbing is costly and often unsatisfying). The Hooker 2055's with accompanying Y will probably suit your needs.
JamesC
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
