Is this possible if i add a Y-pipe?
Old Jul 30, 2008 | 05:36 PM
kamero13's Avatar
ok so i have a stock 86 z28 . Ive taken a look under the car as far as i can see, theres just one straight pipe coming out of where the engine is, then goes down the car until it hits the muffler which has one input and two outputs. So the question is, can i cut the one straight pipe in the middle then add a Y pipe so i can add two mufflers? for example have two SLP loudmouths. Another question is could i cut the straight pipe then add a single input/single output muffler, and after the muffler add a y pipe so i can have two ehaust tips??
Old Jul 30, 2008 | 05:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Split from single pipe to two mufflers = '82-'83 factory system. They used more of a "T" pipe, so it didn't work all that well.
Single in/single out split to two tailpipes - maybe, but why?
What engine/induction do you have? If stock LG4, not much of this makes sense with the restrictive 2-1/4" I-pipe. A '86-'90 TPI single cat aftermarket 3" system with a 3" single in/single out muffler will flow better than any of those options.
Old Jul 30, 2008 | 06:00 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Is this possible if i add a Y-pipe?
You are lucky I saved this pic on my hard disk. It is from another members car, in another country.
Old Jul 30, 2008 | 06:13 PM
kamero13's Avatar
Thats great!! answers my questions completely
thank you very much slow_90firebird.
five7kid, haha im not really sure what engine i have. im only 16 so my knowledge is limited. i "think its like a LB9. the slow model haha
Old Jul 30, 2008 | 06:20 PM
five7kid's Avatar
The 8th character of your VIN will tell what it had from the factory. "H" = base V8, LG4, with carburetor - terrible exhaust from the factory. "F" = LB9, tuned port injection - pretty good exhaust from the factory.
Old Jul 30, 2008 | 06:26 PM
kamero13's Avatar
ok i checked and its a G 305-190 (L69).
any information on this?
Old Jul 30, 2008 | 06:47 PM
Engine: LO3
Thats a sick motor! I would rather have a factory L69 car than any TPI car.
It means you have the 305, carburated, but its the "high output" motor. I also believe that it had a special L69 exhaust and y-pipe that is supposed to be good from the factory.
Old Jul 30, 2008 | 06:57 PM
five7kid's Avatar
Also extremely rare in '86.
I'd want a check on the model year.
But, yes, L69 had the "good" exhaust, like the LB9. In fact, I wouldn't bastardize it.
FWIW, the pictured system is crimp-bent, small I-pipe. A simple mandrel-bent 3" aftermarket system would easily out-perform it.
Old Aug 1, 2008 | 02:06 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
'86 was last year for that engine FYI. Think they stopped putting them in very early during that year too
InfernalVortex
Apr 20, 2021 11:31 AM
mrbird
Oct 20, 2015 03:43 AM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
