Cross Fire Exhaust
Old Aug 4, 2008 | 04:46 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
Cross Fire Exhaust
My car has the funny cross fire injection mufflers (2 mufflers connected by a pipe) does anyone make a performance replacement?
Old Aug 4, 2008 | 04:50 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: Cross Fire Exhaust
mine had that i just cut it all out when i pit my new motor in and went with shorty headers 2 1/2" y pipe 3" from there into the 1 inlet duel outlet flowmaster
Old Aug 4, 2008 | 04:55 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Magnaflow,Spintec, and Flowmaster (in that order) all make similars. If they don't have specific parts, any muffler shop would be able adapt them to work.
Old Aug 4, 2008 | 08:26 PM
Engine: 350 4bbl
Cool thanx so I need a dual in single out and a single in single out then right?
Old Aug 5, 2008 | 12:58 AM
Kevin84Z28's Avatar
Oh, forgot Dynaflow....
Old Aug 6, 2008 | 05:40 PM
Engine: 350 4bbl
Ok so does anybody have part #'s?
Old Aug 12, 2008 | 01:40 AM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
Just search the summit website for catbacks. The flowmaster 86-89 305 tbi system fit my car '83 crossfire car perfectly. With your setup you should probably use 3" pipe. Single inlet and dual exit for muffler.
I noticed a significant difference in top end accerleration when I got rid of the retarded dual muffler setup, and I have a mostly stock 305 CFI. There should be HUGE improvement for you if you're running the combo in your sig with that crossfire exhaust. Hang on tight when you get on it for the first time with the new exhaust!
Old Aug 12, 2008 | 02:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The best performance replacement would be most any aftermarket cat-back made for the '86-'90 TPI single cat application.
Which Hooker headers do you have?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
ericjon262
Sep 11, 2015 06:07 PM
Ranbo108
Sep 9, 2015 12:20 PM
Djmathis123
Sep 8, 2015 08:42 PM
84 TA NV
Sep 6, 2015 08:02 PM
