91 RS 3.1 V6 Dual Exhaust
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I reciently purchased a 91 Camaro RS equipped with the 3.1 V6 and an automatic transmission. The previous owner installed a Flow Master Dual exhaust system.
The previous owner removed the cat and the exhaust now hangs from three wire hangers (two where the cat was located and one on the passenger side exhaust tip).
I also noticed the bracket that held the cat in place is too far from the exhaust line for me to use to secure it.
My question is are there any brackets out there I can purchase (need to know where) to secure this exhaust properly? Does this process involve welding?
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 91 RS 3.1 V6 Dual Exhaust
Exhaust shops will put new hangers on your car for pretty cheap or you can go to any parts store and get ones that are bolt on. They bolt around the pipe and then you have to bolt the top to the body somehow. Either way is going to be pretty cheap. Personally I would get it at a shop as most will replace broken hangers that they installed for free.
vortech305
Jun 3, 2001 11:24 AM
vortech305
Mar 26, 2001 03:21 PM
