Heads,cam,supercharger mods for a 3.1! NOT BAD!!
When i got rid of my 3.1 a week ago(still crying) i found many publications for performance parts for the 3.1 in the 3rd gen camaro/firebirds. MY friend who i recently met has all those mods in his 3.1 and destroyed a twin turbo supra 96' twin turbo 300zx and came close on a 99' Vette. Id write the number of the mods but i doubt people will even look at this post and even bother to buy those mods. However if i see people that are interested all get the information and write back.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
From: First one out of liberty city, burn it to the ground
where the hell did you find a bolt in supercharger? on another post you said u found a bolt in s/c'r for the 3.1 from paxton
" I'd rather run last in a full out race, than to NOT run at all ".
ACK!!! Isn't the suspense great enough yet??????????
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Vman
2.8L V6, 700R4
The supercharger is from Paxton i believe it runs 7 to 8 psi. As of now im in my friends house. Tomorrow (Saturday) ill post all the information about the mods. Keep in mind my friend spent alot of money on his 3.1. Just so everyone knows dont expect to run as fast as him unless u tend on spending big bucks. So like i said look for this post tomorrow (saturday)in the afternoon-evening and ill write it down.
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
Wish you were not back east.
I'm looking for acheap 4 bbl Iron intake for a small block Chrysler!
The mods.....
Paxton stuff is great.
He's had superchargers going on cars since the 50's. Yes, the 50's. One of the people that worked with him, are the same folks that bring you chain saws, Mucullock (misspelled, I know).
Would enjoy reading of the option. Possibly a modified unit to work for our 60*V-6 set up.
Wish it was smog legal in CA.
IS THE SUPERCHARGER, INTERCHANGABLE WITH Small Block Chevy's applications? That detail, I would enjoy knowing. I could use it on 3 cars
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
The mods.....
Chat Soon,
KED85
Karl
OK here are the part #'s for the cam,supercharger and heads:
supercharger is from Paxton. Wow it actually doesnt have the part # but this is what it says on the ad. The Kit for the v6(3.1)engine is both less expensive(2,200) and less labor intensive (4 1/2 hour installation time)than for the v8's. Rear wheel power increased (45 percent)remains the same. I freakin lost Paxton's number but im sure theres a bunch of people in the power adder department that have their number.
The cam is from Crane Cams part # is pending on your application:
part # CRN-254112 rpm 1,000-4,000 $=159.95
Part # CRN-254122 rpm 1,500-4,500 $=159.95
If u need cam specs for both cams ill post it later. CRane says these cam are great for computer controlled vehicles and good for vehicles with performanc chips. Call Summit page is 44.
For the HEads:
Chevrolet is the only source for performance heads for the 2.8 liter and 3.1 liter, 60-degree v6 engines. Chevrolet part # is 14054884 and is a cast iron cylinder head thats used on High Output engines in both transversed-mounted (frontwheel drive) and rear wheel drive applications. This casting is machined for 1.72" diameter intake and 1.42" exhaust valves(standard valve sizes are 1.60" intake adn 1.30" exhaust). Obviously, a slight bump in compression ration, installation of the cam and some porting work are useful in taking in full advantage of the heads airflow capacity.
One more thing the 1987- and later "Generation II" engines are equipped with a canted-valve aluminum head(part # 10048649) that also has a 1.72" intake and 1.42"exhaust valves. Although this head is appealing due to aluminum, its not practical to intall on 86-and ealier engines.
My friend did similar work with his camaro including fully ported and polished the heads. Custom bigger injectors, Rebuild motor with compression down to 8:5:1,ported the plennum,thottle bodie and a bunch of other stuff. Most importantly the exaust system. If u want those power adders to work for u, u must have a complete free flowing exaust system. I hope i helped just a little. I rarely see my friend cause he lives in jersey and races alot so this is the best i can do. Have fun running the V-6 into the V-8 area. later.
92' camaro
Soon to come!!!
Other car;
For the HEads:
92' camaro
Soon to come!!!
Other car;
as for the chysler i have no clue if its interchangeable, this supercharge is for rear wheel drive application i guess u can call paxton for more information sorry. Oh yeah thanks to camaro performance handbook from David Shelby,Summit, and Hot Rod July 1988 issue(add for supercharger) issue #0018-6031 volume 41 Number 7. later.
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
Dude, I just chewed through the entire paxton website and found nothing for the 60* V^. If you could find the part number, or maybe just where he bought it from, that would be VERY lpful to all of us. thanks.
-Reno
'88 Firebird LB8
"Cerberus"
"You think you're weak and maybe I'm the cure, but I've got 6 pistons in my engine, and I got one for ya...it's a long shot"
http://www.angelfire.com/il/Firebird28/index.html
-Reno
'88 Firebird LB8
"Cerberus"
Car: 1986 Firebird
Engine: 2.8 V6
Damn, $2200... that sounds like the cost of a V8 TPI, with engine harness, computer, and transmission to me...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Like i said i just met the guy and i tried to reach him, i did talk to him and he said the camaro came equipped with the paxton supercharger. Did any of u guys go to power adder and find the Phone number from one of the guy who have paxton superchargers in their cars. Ill keep looking if i find it ill let u guys know.
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
2200 bux, does seem like a lot, but all i got for that was a 2.9L v6, that's pretty peppy, but not exactly supercharged material... yet. damn, gotta wait for that 3 year warranty to run out.
I would post a pic of the ad showing the v-6 with the paxton supercharger but i dont know how to. If someone writes in order the main subjectives to post a pic i will get it in. Dont ask for me to email u the pic.
92' camaro
Soon to come!!!
Other car;
92' camaro
Soon to come!!!
Other car;
https://www.thirdgen.org/messgboard/...ML/001246.html
everything you need to know about posting pics
Car: bandit II Firebird
Engine: 3.1
Transmission: auto
Re: Heads,cam,supercharger mods for a 3.1! NOT BAD!!
I was doing some searching for a 3.1l supercharger... found this, and was wondering if anybody figured this super charger out
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Faegol is out of business unfortunately. I think that there is another company who makes one for the 60* but doesn't list it.
Car: 88 prelude si/91 camaro rs
Engine: 2.0/3.1
Transmission: D2J5/700r4
interesting.......i dont think the supercharger would be worth it though.2k for a supercharger for a 3rd gen is alot you can get a better efficent turbo kit for less just my 00.2
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
