Need a cat-back for a 305 TBI
Old Aug 11, 2008 | 11:20 AM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
Im looking to buy a 3 inch cat-back for my 92 camaro with a 305 TBI, i got under the car yesterday and noticed a foot long gash in the intermediate pipe, i guess it just cracked in half. Now i need a new one. I want something that is going to sound good at idle and at cruising speeds, and my price range is from $350 to $400. Any advice on which system to go with?
Old Aug 11, 2008 | 07:32 PM
Re: Need a cat-back for a 305 TBI
anyone???, i plan on buying a system in the next couple of day and i would like to know if i get the right one
Old Aug 11, 2008 | 08:44 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Find a used Borla system!!! I bought mine on ebay for $275. It's stainless steel, so it'll last a looong time.
Old Aug 12, 2008 | 09:24 AM
i was thinking about this system from jegs, its a little more than i wanted to spend but its stainless steel and will last a long time.
http://www.jegs.com/i/Magnaflow/642/16829/10002/-1
Old Aug 12, 2008 | 09:58 AM
bcnvz28's Avatar
Car: 16 Equinox,12 Silverado,91 Z28
Engine: 3.6l, 5.3l, 305 H.O.
Transmission: 6 Spd auto, 6 Spd Auto, 4 spd Auto
Check out Magnaflows website, they have video of a third -gen.
http://magnaflow.com/
I bought one of their catbacks from this company:
http://www.hottexhaust.com/index.htm
Do a google search for them and look for discount codes.
I used "veedub" and paid $360.00
I also got a cat from here: http://www.discountperformanceautoparts.com/
Old Aug 12, 2008 | 10:18 AM
cityspud117's Avatar
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
check out hookers aero chamber system...i used it on my 305 tpi sounded great
Old Aug 12, 2008 | 11:15 AM
thanks for the info, i did check out magnaflows website, but the clip they have is of a 350 TPI, and i know it will sound different on my 305 TBI.
Old Aug 12, 2008 | 12:11 PM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
I'd probably try to avoid 3" exhaust on a TBI 305. When I had my TBI 89 Formula, I put a 3" dynomax CVX kit on it and pulled the cat. It sounded really good, but my fuel economy suffered and I really think the car made slightly less power with the larger exhaust (this was years ago, in the time before dynojets began to roam the land). If I personally did another TBI car, I'd probably stick with a 2.5 or 2.75" exhaust.
Your results may vary.
Old Aug 12, 2008 | 12:36 PM
Do you know of a smaller system that i could go with that is stainless steel? or do you know of another system that works good with TBI?
Old Aug 12, 2008 | 04:05 PM
jamieschott's Avatar
I put the magnaflow 16829 as well as a magnaflow hi flow bullet cat on my 92 rs that has 305 tbi, i love it. before i put it on there was NO muffler due to "rustation", if thats a word but anyway after install, i noticed that it wasnt any quieter. reccomend this!
here is video clip of magnaflow, keep in mind everything is stock 'cept for cat and cat back. http://www.youtube.com/watch?v=PjrgbadwhfA
i purchased this from hottexhaust for 426 shipped including the retail $ 90 cat.
Old Aug 12, 2008 | 07:15 PM
that video was very helpful i been looking for a video of a stock camaro with that system. does it sound good at cruising speeds?
Old Aug 13, 2008 | 01:30 AM
It has a very nice deep tone at cruising speeds. i wish i would ve taken video at cruising speed and WOT. but didnt have time while i was home. I did this while i was on leave from iraq and now im back there reading about all this great 3rd gen stuff. so it will be awhile before i get to video anymore stuff.
Old Aug 13, 2008 | 12:39 PM
ok, i talked to a local exhaust shop today, and they said that if i get a 3 inch system it should not affect back pressure or my fuel economy, they said if i mess with the cat it would affect that because the back pressure is built up at the cat, now is this true or not?
Old Aug 13, 2008 | 01:01 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Go magnaflow mine sounds amazing
Old Aug 15, 2008 | 08:21 PM
Im probably going to be ording the magnaflow system within a couple days, but before i order it i have a question. All of my dads friends build hot rods for a living, and they all said that since my motor is not making a lot of horsepower i dont need a 3 inch system and that it will not create enought back pressure and will hurt my fuel economy. I called a local muffler shop and they said the back pressure is created at the cat. I dont know what to believe, which is true. Any and all help would be appriciated.
Old Aug 18, 2008 | 11:05 AM
anyone???
Old Aug 18, 2008 | 12:06 PM
bcnvz28's Avatar
Check out this "sticky". Lots of good info, techincal in theory, with good conclusions. Check all responses also.
https://www.thirdgen.org/forums/exha...-you-ever.html
Old Aug 20, 2008 | 09:55 AM
19transam86's Avatar
Car: 86 trans am
Engine: 5.0 305
Transmission: 5 speed
I believe that the bigger exhaust will hurt backpressure, i never heard of the cat creating the backpressure for the whole exhaust. i orderd a dynomax cat back system from summit for $184 2.5'' and stainless steel. it sounds great at idle and there is still a good rumble at cruising. at lower RPM's it sounds alot meaner then at 2500 and up
Old Aug 20, 2008 | 10:25 AM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Magnaflow just installed!!! Incredible sound. Can't believe the richness of the sound. A nice deep rumble at idle that is "soft" sounding. WOT it really sounds mean in a good way, lol. I got mine for $350. Shop around you'll find a good deal.
Old Aug 21, 2008 | 07:59 AM
Do you have a part number on that?
Old Aug 21, 2008 | 10:51 AM
Car: 86 trans am
Engine: 5.0 305
yeah at summit it WLK-17495 for a H.O. from 82-92 5.0/5.7 dual tailpipes and the one i orderd for $184 is # WLK-17493 for 83-92 2.8/3.1/5.0 dual tailpipes. installation is fairly easy, you need to get all 4 wheels of the groung and then just drop two crossmember supports with a couple bolts and then you have the room to get the exhaust over the rear end. Be careful for the brakline because i busted my right rear brake in the process but it was alredy decrepit and should have been replaced for saftey.
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
