Buying headers and y-pipe next week WHAT SHOULD I GET!
Old Aug 23, 2008 | 04:24 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok guys i took the air lines off and everything and my plugs will un screw them self every once and a while and now i just want to put headers on with a new y-pipe. I want to put the biggest headers and y-pipe on my car. They will also be put on a modded 350 once i get one so ANY IDEAS PLEASE HELP!
thanks
kevin
Old Aug 23, 2008 | 04:31 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: Buying headers and y-pipe next week WHAT SHOULD I GET!
Do a search, bet you will find everything.
Old Aug 23, 2008 | 09:45 PM
Ok i looked a little didnt find a hole lot out. So will some one please tell me a good performance headers and y-pipe. I do not have a cat no more so will it be better to go with long tubes? I need something that will go good with a 350 with some real hp.
thanks
kevin
Old Aug 23, 2008 | 11:09 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
https://www.thirdgen.org/forums/exha...oker-long.html
For shorties go with dyno dons [PM him on here] or since you dont have AIR look into the Hooker 2460s.
Old Aug 25, 2008 | 03:22 PM
kaitlin's Avatar
Car: 92 rs conv
Engine: 3.1
Transmission: a4
Axle/Gears: 3:42
you could go w 2055 w/ypipe and cut tubes off and weld them
Old Aug 25, 2008 | 05:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bad move. I suggest you read some of the stickies on headers first.
Old Aug 25, 2008 | 05:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
And/or a bit more research. There're two tons of info about the subject.
JamesC
Old Aug 25, 2008 | 06:50 PM
so no one can tell me a good performance headers and y-pipe?
kevin
Old Aug 25, 2008 | 07:18 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
alot of guys use the hooker 2210's and make their own y pipe into a 4in back section from mufflex
Old Aug 25, 2008 | 09:18 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
kevin
I showed you these, but you didn't want to spend any money.
Old Aug 25, 2008 | 09:29 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Hey dyno don, I bought a set of your shorties with the y, is there anyway to modify your y pipe to fit a 3.5 mufflex catback?
Old Aug 25, 2008 | 11:12 PM
five7kid's Avatar
Not without specifics. For all we know, your 350 won't need anything more than 1-1/2" Pacesetters. If you talked to Dyno Don, he isn't going to steer you wrong.
Hooker 2055HKR's work well with a whole bunch of combos.
If you think you can have "good" and "cheap", as always you'll get what you pay for - and maybe less.
Old Aug 25, 2008 | 11:22 PM
Dyno Don's Avatar
You would have to cut right at the connection of the two pipes and weld on a 3 1/2" collector.
I can get one of those for you.
Old Aug 26, 2008 | 08:18 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
How much do one of them cost Don?
Old Aug 26, 2008 | 09:50 PM
How much do you want for them? Will these also be good for a 400-500 hp 350?
thanks
kevin
Old Aug 27, 2008 | 07:44 AM
Doug Phillips's Avatar
Car: 85 IROC race car
Engine: 425/435 rwhp/tq
Transmission: WCT5 .80 5th gear
Axle/Gears: 3:42
Dyno Don. I have sent you a few messages asking about pricing for my 383 5 speed carb road race car currently with 370 tq.No replys yet. Does anyone have pricing or is there a web site?
Old Aug 27, 2008 | 01:06 PM
Dyno Don's Avatar
Check PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
downsouthboy
Aug 29, 2015 11:29 AM
Out-Cast
Aug 22, 2015 07:49 PM
